March 16, 2024, 14:37 |
Issue with MULES alpha
Michael
Rep Power: 2 |
Hello everyone,
I am having an issue with the interfoam solver. I have a water flowing through the model with an inlet and outlet. I also have air on top of the water. When I have flow=0, I have no issue running. When I start flow (specifying an inlet velocity), I have an issue where my max alpha in MULES goes above 1 (which shouldn't happen, and my pressure goes crazy. Has anyone had a similar issue and had a fix? I think it may have to do with the interface between the phases (air and water) changing but am unsure. Thank you for your help! |
March 17, 2024, 10:36 |
Michael Sukham
Rep Power: 6 |
Any chance of sharing the case or sharing the U p_rgh (or pd )?
March 21, 2024, 20:56 |
Michael
Rep Power: 2 |
So I was able to fix the problem, I had forgot to designate a boundary and it was "default face". Now I am having issues with my alpha value gets very high and low (2*10^18 and -2*10^18) and then crashing. In addition, I have a "wall" with a zero gradient designation getting alpha values below 1 but this is before crash (it is under water by quite a ways, should not be getting anything below 1). I would post a screenshot but can not figure out how to do that, it says I keep getting denied. Does this problem ring a bell to anyone? I have one inlet, an outlet, a wall, and an atmospheric top. Alpha BC's Inlet:type fixedValue; value uniform 1; Outlet: zeroGradient Wall:zeroGradient Atmospheric Top: type inletOutlet; inletValue uniform 0; value uniform 0; Do these boundary conditions seem reasonable? |
March 21, 2024, 22:05 |
Michael
Rep Power: 2 |
It is supposed to be open channel flow.
My U boundary conditions are... wall: fixed value uniform (0 0 0) inlet: fixed value uniform (1 0 0) outlet: zeroGradient Top: pressureInletOutletVelocity uniform (0 0 0) My P boundary conditions are... wall: fixedFluxPressure inlet: fixedFluxPressure outlet: fixedFluxPressure Top: total pressure uniform 0; Could the issue be with one of these? |
March 21, 2024, 23:04 |
Michael Sukham
Rep Power: 6 |
For the pressure in outlet, try the zeroGradient bc. Other bc's look fine.
With regards |
March 22, 2024, 00:34 |
Michael
Rep Power: 2 |
Thank you for the response! I tried the zeroGradient but now I am getting pressure GAMG value to crash. My alpha values at the crash are still quite large (+- 10^9). My crash occurs after about 0.4 seconds of runtime. Do you have any other suggestions on what may be the issue? I tried "check mesh" and it came back with everything being ok |
March 22, 2024, 09:23 |
Michael Sukham
Rep Power: 6 |
Can you share the case here. I would like to run and check it. I am not an expert but maybe I can look at the case and report it to you.
With regards. (Share zip file). I would put zeroGradient for the inlet as well for pressure. |
March 25, 2024, 12:35 |
Michael
Rep Power: 2 |
Does anyone have an idea on what my pressure boundary condition should be for a boundary that is immediately above the inlet (which has wetting fluid going through it at a specified velocity), and is just exposed to what should be a normal atmosphere?
[OLAFLOW] The OLAFLOW Thread | Phicau | OpenFOAM Community Contributions | 459 | September 12, 2024 12:47 |
Supercavitation / overPimpleDyMFoam | canik01@yahoo.com | OpenFOAM Running, Solving & CFD | 28 | September 6, 2021 12:07 |
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel | Mehrez | OpenFOAM Running, Solving & CFD | 10 | May 18, 2016 12:44 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 08:09 |
Alpha to be phased out | Heiko Gerhauser | Main CFD Forum | 17 | July 25, 2001 15:40 |
