March 16, 2024, 14:28 |
Bad Pressure Distribution
Alan w
Rep Power: 6 |
In my efforts to debug my chtmultiregion case, I finally got it to create data! Then when I went to paraView, the pressure Distibution (see attached image) has an obvious problem, with high pressure at the inlet, and low pressure at the outlet, ignoring the body in the domain. I have been thrashing this for a couple of days, so far without luck. It could well be that someone amongst the community has seen this problem and found a fix for it; if so, could please! share your experience with me. |
March 19, 2024, 11:18 |
#2 | |
Ching Liu
Rep Power: 9 |
March 19, 2024, 13:27 |
Than you qingqingliu
Alan w
Rep Power: 6 |
Thanks for your response!
In a steady state simulation, although there may be slight pressure changes in the domain, I would expect it to be basically consistent, and show only the changes due to perturbations around the body, as shown in the attached. However, in my problem case, there is a huge pressure change between the inlet and outlet, which cannot be right! |
March 19, 2024, 13:33 |
#4 | |
Ching Liu
Rep Power: 9 |
Suction pressure distribution at the bottom caused by a ship propeller | loewieke53 | OpenFOAM Running, Solving & CFD | 0 | April 6, 2020 07:41 |
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions | Vishnu_bharathi | CFX | 12 | November 21, 2017 07:56 |
Pressure distribution | Tunlu | FLUENT | 0 | October 19, 2013 22:47 |
pressure distribution in water flow, differences in icoFoam and COMSOL | deniggo | OpenFOAM Running, Solving & CFD | 14 | September 30, 2010 04:48 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 15, 2003 00:19 |
