Shot Sleeve Wave Dynamics using InterFoam. Interface capturing at corner areas. |
March 13, 2024, 05:56 |
Michael Sukham
Rep Power: 6 |
Hello and greetings. I am simulating the wave dynamics in shot sleeve of high pressure die casting. I have the meshing done by SnappyHexMesh which produced a hex dominated mesh with some tet on the edge of the cylinder. Mesh motion is achieved by velocityComponentLaplacian since I have a moving plunger only in the x-direction. The motion is done by codedFixedValue in pointMotionUx.
My problem is when the liquid reached the corner of the cylinder at top. the interface by using MULES cAlpha 1 gives some oscillations. Making cAlpha = 0 smears the interface but it does give a very nice interface by setting iso value at 0.5 in post-processing. I have some way in my mind 1. Refining the edge cells using a higher refinement of feature edge. 2. Using isoAdvector. (Although I am not sure of the settings with dynamic mesh) 3. Using cAlpha 0 and refining the feature edge cells. I had some success with mapFields by extracting the stl file from latestTime using surfaceMeshExtract -latestTime and remeshing using snappy and mapping on the new mesh the field values. But again when ever the interface touches the upper corner, the problem persist. InterfaceCapturing on these corner points seems to give me the errors. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class pointScalarField; object pointMotionUx; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform 0; boundaryField { movingWall { /*type uniformFixedValue; uniformValue constant -0.2; */ type codedFixedValue; value uniform 0; name increaseToFixedValue; code #{ const scalar t = this->db().time().value(); const scalar a = 1.8; const scalar b = 0.0254; operator==(a*b*(exp(a*t)-1)); #}; } sleeveWall { type slip; } axiSymmetric { type slip; } endWall { type uniformFixedValue; uniformValue constant 0; } outletWall { type uniformFixedValue; uniformValue constant 0; } outlet { type uniformFixedValue; uniformValue constant 0; } } Code:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { div(rhoPhi,U) Gauss linearUpwind grad(U); // Gauss vanLeerV div(phi,alpha) Gauss interfaceCompression limitedLinear01; //Gauss vanLeer; div(phirb,alpha) Gauss interfaceCompression; //Gauss vanLeer; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
