Courant number is spiking in very small section |
Desh
Rep Power: 5 ![]() |
Hi All,
I am running a venting event in 2D wedge domain with rhoPimpleFoam in OF10. Please see the attached figure. My fluid domain is roughly 0.7 m (height) x 0.1 m (radius) of a wedge. From the bottom surface of the wedge I've assigned my outlet. The question is solver is choosing very small time stepping (1E-9/10). Reason for this is only few cells Co no is reaching to 1 whilst all the rest remains under 1e-8 or so. My mesh is clean, and no errors at all.. How can I avoid this few cells Co being increased so I can increase my overall time stepping ? Any insights are highly appreciated. Thank you. Dasith |
Desh
Sorry forgot to attached the figure
Josh Williams
#4 | |
Desh
Hi, Thank you for your reply. Apologies for the misinterpretation of the problem. The mesh in the figure is only one iterations of me trying to avoid the Co spike. I tried simpleGrading to make the mesh for uniform/refine/course basically everything. Nothing works. However that boundry has a pressure gradient of delataP = 200MPa- 0.1MPa Following are the pressure and velocity boundary conditions I am using; PHP Code:
PHP Code:
Thank you |
courant number |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
Courant Number | waseeqsiddiqui | FLUENT | 3 | December 27, 2018 10:43 |
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 22:29 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
