February 28, 2024, 06:24 |
nut, nutilda
onurlands
Rep Power: 2 |
Hello, I want to realize an aerodynamic solution for incompressible flows under standard atmospheric conditions. I use simpleFoam as a solver. What should I enter in the Nut and Nutilda section?
rho [1 -3 0 0 0 0 0] 1.225; nu [0 2 -1 0 0 0 0] 1.461e-05; p: 101325 Pa |
February 28, 2024, 06:44 |
Rep Power: 14 |
The short answer is "suitable values".
In other words, you need to calculate what these values are for your flow scenario. |
February 28, 2024, 06:55 |
#3 | |
onurlands
Rep Power: 2 |
As a second question, I would be glad if you could answer it. I want to perform an aerodynamic analysis in openfoam. I making simpleFoam solver. There is no T file in folder 0, can I create it myself and enter the temperature value? |
February 28, 2024, 07:09 |
#4 | ||
Rep Power: 14 |
February 28, 2024, 07:18 |
#5 | |
onurlands
Rep Power: 2 |
Let's say I have determined the appropriate solver. And I am interested in T,p,U,nut,Nutilda files. But there are also files such as k and omega in the 0 folder of that solver. Can I delete them? After deleting them from there, do I need to delete them from somewhere else, for example from the fvSolution file? |
February 28, 2024, 08:09 |
#6 | ||
Rep Power: 14 |
A short cut is to delete the files and then try to run the solver - it will then crash & complain if it is missing a file. Quote:
Good luck my friend. |
nut, nutİlda |
nut and nuTilda | phile | OpenFOAM Running, Solving & CFD | 32 | June 13, 2020 09:53 |
not another motorbike question | nutilda - nut fields | hulli | OpenFOAM | 2 | December 4, 2017 13:38 |
nut nutilda SpalartAllmarasDDES revisited | hulli | OpenFOAM Pre-Processing | 1 | July 20, 2017 04:01 |
nut and nuTilda in simpleFoam | mich_K | OpenFOAM Running, Solving & CFD | 2 | August 8, 2014 04:38 |
nut and nuTilda in simpleFoam | mich_K | OpenFOAM Running, Solving & CFD | 0 | August 7, 2014 14:42 |
