deforming mesh with AMI
Old   February 27, 2024, 10:51
Default deforming mesh with AMI
Rithwik Kandukuri
rkandukuri is on a distinguished road
Hi. im using OFv2306. trying to simulate a VAWT with a heaving motion superimposed. Due to problem geometry constraints, my airfoil wall is extremely close to my AMI interface. Due to this constraint, I think the cells near the AMI interface get heavily skewed a few time steps in. I'm working on refining the mesh right now. Other pointers to fix this issue, or alternative methods to acheive this would be great ( tried overset meshes, not been very succesful with it, case is very transient and pressure oscillations are too uncontrollable ) . I'm attaching my pointDisp and dynamicMeshDictFiles
dynamicMeshDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      dynamicMeshDict;
dynamicFvMesh dynamicMultiMotionSolverFvMesh;   //dynamicMotionSolverFvMesh;
// Specification of rotation around centre
dynamicMultiMotionSolverFvMeshCoeffs
    dualWing1
        cellZone innerVar-cells;
        solver solidBodyDisplacementLaplacian;
        solidBodyDisplacementLaplacianCoeffs
            solidBodyMotionFunction  multiMotion;
            multiMotionCoeffs
                rotation_2
                    // Apply counter rotation to keep dualWing aligned
                    solidBodyMotionFunction rotatingMotion;
                   rotatingMotionCoeffs
                       origin      (0 2.527 0);;
                       axis            ( 0 0 1);
                       omega            1.7453;    //5.52 rad/s
            diffusivity quadratic inverseDistance ("var_foil1");
pointDispacement
dimensions      [0 1 0 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    back
        type empty;
    bottom
     type symmetryPlane;
    front
        type   empty;
    inlet
        type            fixedValue;
        value           uniform (0 0 0);
    outerSliderBase
        type            cyclicAMI;
    type            fixedValue;
        value           $internalField;
    outerSliderVar
         patchType       cyclicAMI;
        type            fixedValue;
    outlet
        type            fixedValue;
    top
         type           symmetryPlane;
    innerSliderVar
        type            fixedValue;
    base_foil1
        type            fixedValue;
    var_foil2
        type            fixedValue;
    var_foil1
        type            solidBodyMotionDisplacement;
        solidBodyMotionFunction oscillatingRotatingMotion;
        oscillatingRotatingMotionCoeffs
            origin          ( 0 2.527 0 );
            axis            ( 0 0 1 );
            omega           3;
            amplitude       ( 0 0 5 );
    base_foil2
        type            fixedValue;
    innerSliderBase
        type            cyclicAMI;
    type            fixedValue;
rkandukuri is offline   Reply With Quote
ami, mesh deformation, openfoam, skewed cells, v2306
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
