sixDoFDynamicMotion
Old   February 19, 2024, 15:18
Default sixDoFDynamicMotion
onurlands
onurcanpiskin is on a distinguished road
I want to perform an oblique shot of a solid object within the boundary volume, simulate this and at the same time calculate where it will fall.
I will ask you a few questions one by one and I would be very happy if you could answer them.
1- I perform the mesh operation on Salome. Before performing mesh, when creating the boundary volume, do I need to remove the part to be discarded from the boundary volume?
2- Let's assume that this is a very simple example. To solve this problem, would it be enough to define the limit volume and the object to be thrown in the files in folder 0? How should I define these (noslip, fixedvalue etc. I would appreciate it if you could explain these parts)
onurcanpiskin is offline   Reply With Quote
Old   February 20, 2024, 04:25
Yann
Yann will become famous soon enoughYann will become famous soon enough
Have you run the case I mentioned on this post: icoUncoupledKinematicParcelFoam ?
The whole case is available on github: https://github.com/nicolasbadano/OversetSkipping
This is a good start, running it and studying how it is setup should put you in the right direction to set your own case.
Cheers,
Yann
Yann is offline   Reply With Quote
Old   March 5, 2024, 07:13
Post Dynamic Code Error
Magnus Jackson
mjackson is on a distinguished road
I have been working on setting up a ship simulation case, using overInterDyMFoam, and have been having an issue with the dynamicCode folder and the dynamicMeshDict. The error message I have been receiving is shown below:
Could not load "/home/mjackson/OpenFOAM/mjackson-v2312/run/meshStudy/testCase/background/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_bb399afaaa216c908409d159545e7fafbfa984fb.so"
/home/mjackson/OpenFOAM/mjackson-v2312/run/meshStudy/testCase/background/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_bb399afaaa216c908409d159545e7fafbfa984fb.so: cannot open shared object file: No such file or directory
    ln: ./lnInclude
make: /usr/lib/openfoam/openfoam2312/platforms/tools/linux64Gcc/wmkdepend: No such file or directory
make: *** No rule to make target 'Make/linux64GccDPInt32Opt/codeStreamTemplate.C.dep', needed by 'Make/linux64GccDPInt32Opt/codeStreamTemplate.o'.  Stop.
[0]
[0]
[0] --> FOAM FATAL IO ERROR: (openfoam-2312)
[0] Failed wmake "dynamicCode/_bb399afaaa216c908409d159545e7fafbfa984fb/platforms/linux64GccDPInt32Opt/lib/libcodeStream_bb399afaaa216c908409d159545e7fafbfa984fb.so"
[0]
[0]
[0] file: constant/dynamicMeshDict/sixDoFRigidBodyMotionCoeffs at line 26.
[0]
[0]     From static void (* Foam::functionEntries::codeStream::getFunction(const Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&)
[0]     in file db/dictionary/functionEntries/codeStream/codeStream.C at line 188.
[0]
FOAM parallel run exiting
[0]
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
My dynamicMeshDict is shown here:
|  \\    /   O peration     | Version:  v2312                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      dynamicMeshDict;
motionSolverLibs    (sixDoFRigidBodyMotion);
dynamicFvMesh       dynamicOversetFvMesh;
solver              sixDoFRigidBodyMotion;
    patches         (floatingObject);
    innerDistance   0.2;
    outerDistance   1.0;
    centreOfMass    (-1 0 -1);
    // Cuboid dimensions
    Lx              18.28;
    Ly              5.4;
    Lz              2.0;
    // Density of the solid
    rhoSolid        38.5;
    // Cuboid mass
    mass            #eval{ $rhoSolid*$Lx*$Ly*$Lz };
    //mass            #calc "$rhoSolid*$Lx*$Ly*$Lz";
    // Cuboid moment of inertia about the centre of mass
    momentOfInertia	#codeStream
		codeInclude
			#include "diagTensor.H"
		code
			scalar sqrLx = sqr($Lx);
			scalar sqrLy = sqr($Ly);
			scalar sqrLz = sqr($Lz);
			os  <<
				$mass
				*diagTensor(sqrLy + sqrLz, sqrLx + sqrLz, sqrLx + sqrLy)/12.0;
    report          on;
    accelerationRelaxation 0.6;
    accelerationDamping    0.9;
    solver
        type Newmark;
    constraints
        fixedPoint
             sixDoFRigidBodyMotionConstraint point;
             centreOfRotation (0.5 0.45 0.1);
        fixedLine
            sixDoFRigidBodyMotionConstraint line;
            //centreOfRotation (0.5 0.45 0.1);
            direction (0 0 1);
        fixedAxis
            sixDoFRigidBodyMotionConstraint axis;
            axis (0 1 0);
And in the control dict I import the libs: libs (overset fvMotionSolvers);
To try and solve this issue I have uninstalled and reinstalled 'make', I have changed the libraries imported and have remade the whole case from scratch again.
I am quite new to openFoam so there is a good chance I have made a simple syntax error or am using the wrong libraries. However, if anyone has some tips, it would be greatly appreciated!
Many thanks, Magnus
mjackson is offline   Reply With Quote
sixdofdynamicmotion
