February 17, 2024, 11:24
Solver for a heated pump problem
Dear collective internet expertise,
Long story short. I want to simulate a heated water pump with openFoam (v2312) and I am not sure if OpenFoam provides the necessary solvers. Questions follow below.
I. Requirements:
A. Physics:
1. constant density flow (incompressible + constant density, because water)
2. non-isothermal (due to heating)
3. conjugate heat transfer (due to interaction heating element <-> fluid)
4. turbulence (due to a too high Reynolds number)
B. Solver:
1. transient
2. dynamic mesh (rotating zone due to the pump impeller)
3. multi-region (due to conjugate heat transfer) II. Assessment:
The problem seems to be that there is no solver for my problem that can do both conjugate heat transfer and dynamic mesh.
Sources:
(https://www.openfoam.com/documentati...andard-solvers)
(https://www.openfoam.com/documentati...s-solvers.html)
Alternative idea:
I split the calculation into a fluid dynamic and a heat transfer part. III. Questions:
1. Is there really no solver that meets my requirements?
2. Is it possible to implement the alternative and first calculate the velocity field and then use it for a separate conjugate heat transfer calculation of the temperature field? Thank you very much.
