Very strange results with turbulent simpleFoam simulations on airfoil
Old   February 14, 2024, 17:29
Default Very strange results with turbulent simpleFoam simulations on airfoil
Tommy Nee
tnee3 is on a distinguished road
Hi!
I’d firstly like to apologise for how open ended this post is going to be. I’m trying to run 2d turbulent simulations of an airfoil using simpleFoam, and meshing with snappyHexMesh.
When I run the case without the viscous layers added, obviously my values are wrong as the boundary layer is not resolved but it runs okay. However when I add the viscous layers, the simulations produce very strange velocity plots in paraview. I will attach some of these plots below.
I know this is very broad and I’m sorry but I’m completely stumped by it. Any help on this would be really great, thanks!
I’ve also attached my snappyHexMeshDict, controlDict, and initial conditions for velocity pressure and turbulence model parameters (k-omega SST model). Please let me know if there’s any other files I should upload.
Files.zip
tnee3 is offline   Reply With Quote
Old   February 15, 2024, 06:38
Sami Safarini
samisafarini is on a distinguished road
Is the simulation for a wind tunnel? it seems odd that your top and bottom are nonslip. I find setting a pressure of 0 gives me problems have you tried setting it as absolute atmospheric i.e. 100kpa?
Can you share the whole sim folder with us?
samisafarini is offline   Reply With Quote
Old   February 16, 2024, 11:47
Tommy Nee
Hi there, thank you for responding to me, sorry I took a while to respond.
My issue actually ended up coming down to my mesh, it simply was not good enough. I was also using renumberMesh to optimise it as I read somewhere to do that and for whatever reason that was giving me the second very strange plot. I have somewhat fixed the issue now, but still need to refine the mesh further to solve the boundary layer. Thanks again for the response though!
boundary layer mesh, simplefoam, snappy hex mesh, turbulent
How to understand differences between simpleFoam and icoFoam results for airfoil Jay_CFD OpenFOAM Running, Solving & CFD 5 December 31, 2023 07:18
Calculation of lift and drag coefficients on airfoil CoolHersheys OpenFOAM Post-Processing 5 September 27, 2021 07:04
NACA 0012 (3D) strange results? aleix.de.toro FLUENT 0 December 19, 2014 12:39
2D FFD Optimization RLangtry SU2 2 August 5, 2014 10:48
Airfoil y+ Results Query asd Main CFD Forum 1 June 22, 2007 09:02
