February 13, 2024, 09:14 |
Running SolidParticle in parallel
Varun Venkatesh
I am a beginner and I am trying to implement a very simple particle in fluid model. I found this tutorial:https://www.tfd.chalmers.se/~hani/ku...iclesInVOF.pdf I am trying to implement the tutorial and it works exactly as it should when i run it in serial. However, when trying to run it in parallel, the particle is not even recognized to exist. There is no lagrangian output and the log file makes no mention of a lagrangian. I don’t know how to even begin to search for a solution to this because there is no error message. My code is exactly as in the slides. I chose SolidParticle over one of the KinematicParcel’s because it is simple and I understand how to make modifications to it. Any help is very much appreciated Best, Varun |
lagrange particle, parallel, solidparticlefoam |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 17:38 |
error while running in parallel using openmpi on local mc 6 processors | suryawanshi_nitin | OpenFOAM | 10 | February 22, 2017 22:33 |
Fluent 14.0 file not running in parallel mode in cluster | tejakalva | FLUENT | 0 | February 4, 2015 08:02 |
Problems running in parallel - missing controlDict | Argen | OpenFOAM Running, Solving & CFD | 4 | June 7, 2012 04:50 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 08:52 |
