Anurag
Rep Power: 3 ![]() |
Hi all,
I refined a mesh in a geometry and then it started reaching very high Co of 1e+40 and the simulation is failing. I have reduced the time-step to 1e-10 and switched on adjusttimestep with a max Co .25, but still the Co is reaching very high values and the simulation is failing. I have checked the mesh, it seems fine with a min edge length of 1e-3. Should i try something else? like schemes or relaxation factors? or should i check my mesh first, i created the mesh in ansys using multizone. It will be very helpful if someone can provide insght. Many Thanks. Ani |
Shravan
Rep Power: 9 ![]() |
There could be many reasons. You have not given much information. Could you post here the output of checkMesh? Then what are the fvSchemes and fvSolutions? By looking into these, we can get a better idea. Thanks |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
[Other] Equal decomposition of cylindrical fluid domain | Sean95 | OpenFOAM Meshing & Mesh Conversion | 3 | February 12, 2019 03:34 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
