February 5, 2024, 09:14 |
Mapfield error
Abhishek Roy
mapFields -consistent -sourceTime 'latestTime' ../2m/
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 7-3bcbaf946ae9 Exec : mapFields -consistent -sourceTime latestTime ../2m/ Date : Feb 05 2024 Time : 19:34:50 Host : "abhishek-H110" PID : 18764 I/O : uncollated Case : /home/abhishek/Desktop/try_mapfield/4m nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Source: "/home/abhishek/Desktop/try_mapfield/2m" "" Target: "/home/abhishek/Desktop/try_mapfield" "4m" Create databases as time Source time: 0.122 Target time: 0 Create meshes Source mesh size: 1994104 Target mesh size: 4142448 Consistently creating and mapping fields for time 0.122 interpolating nut #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/mapFields" #4 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/mapFields" #5 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/mapFields" #6 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/mapFields" #7 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/mapFields" #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/mapFields" Segmentation fault (core dumped) I am getting this error while using mapFields |
February 5, 2024, 12:36 |
Saeed Jamshidi
Rep Power: 8 |
mapfields |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
