Rhosimplefoam crashes after "Selecting thermodynamics package "
Old   February 1, 2024, 06:52
Default Rhosimplefoam crashes after "Selecting thermodynamics package "
Sami Safarini
samisafarini is on a distinguished road
Hi All,
I was able to run my mesh with simpleFoam without a problem, I now want to run it for a compressible turbulent flow case and I have chosen rhoSimpleFoam and sonicFoam as options. but in both cases I get the following error.
Has anyone experienced this before?
    type            heRhoThermo;
    mixture         pureMixture;
    transport       sutherland;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
[stack trace]
#1  Foam::sigFpe::sigHandler(int) in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#2  ? in /lib/x86_64-linux-gnu/libc.so.6
#3  ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so
#4  ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so
#5  ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so
#6  Foam::fluidThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::New(Foam::fvMesh const&, Foam::word const&) in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so
#7  ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so
#8  Foam::fluidThermo::New(Foam::fvMesh const&, Foam::word const&) in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so
#9  ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam
#10  ? in /lib/x86_64-linux-gnu/libc.so.6
#11  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#12  ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam
Floating point exception (core dumped)
samisafarini is offline   Reply With Quote
Old   February 4, 2024, 11:24
Sami Safarini
It seems that the boundary condition for pressure was set to 0.0 and that was causing the problem.
rhosimplefoam error
[foam-extend.org] foam-extend-4.1 cannot compile on Centos8 Ya_Squall2010 OpenFOAM Installation 2 July 22, 2020 03:03
[foam-extend.org] paraview not runing? (foam extended 3.2 and ubuntu 15.04) Milan2013 OpenFOAM Installation 23 April 20, 2017 06:49
[OpenFOAM.org] Building OpenFOAM 3.0.1 on Ubuntu 16.04 - failed erico OpenFOAM Installation 30 February 2, 2017 10:24
OF 1.6 ext on Ubuntu 12.10 (64 bit) compilation errors dreamilam OpenFOAM Installation 7 April 21, 2013 06:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
