Which solver should I use for phase changing material (PCM) modeling?
Old   January 26, 2024, 09:55
Default Which solver should I use for phase changing material (PCM) modeling?
Kristine
kristinemidtbo is on a distinguished road
Hi!
I'm currently trying to solve a problem with a phase changing material (PCM) in a tank which is heated/cooled by a pipe running through the tank.
The model needs to be laminar, multiregional (possible to model the PCM-region, the pipe and the water inside of the pipe), phase changing (the PCM), and it needs to model the thermodynamics in the system.
The question is then, what solver do I use?
I've been thinking about using chtMultiRegionTwoPhaseEulerFoam, but it is a complex solver and I cannot find any tutorials or good explanation on how to build this type of simulation.
Is there anyone who have a better alternative for solving this problem? Or maybe some of you have a tutorial for me so I can make chtMultiRegionTwoPhaseEulerFoam work for this case?
kristinemidtbo is offline   Reply With Quote
multiphase model, multiregionsolver, pcm, phase change, solver coupling
reverse flow in centrifugal fan blades kalm CFX 20 December 2, 2023 07:25
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 07:33
CFD Analysis on Phase Changing Material (PCM) Naveenjanj CFD Freelancers 0 September 8, 2020 00:32
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
