Help on 2D laminar incompressible airfoil simulations |
Tommy Nee
Rep Power: 2 ![]() |
Hi!
I'm quite new to OpenFOAM and am running into some issues when trying to run a 2D simulation of a NACA0012 airfoil under laminar, incompressible conditions. I'm using blockMesh to perform the mesh and a Reynold's number of 10,000. I cannot seem to get anything but very refined meshes to converge, and even those more refined meshes won't converge under an angle of attack of even as high as 5deg. I have to perform a mesh sensitivity study so I do need to have coarser meshes running also. Any help on this would be greatly appreciated! I have attached all the files below, and an image of the mesh. Thanks! |
Tommy Nee
Sorry I should've also mentioned, I'm using the simpleFoam solver!
I am not sure how to help you.
I assume you have seen OpenFoam airfoil tutorials, see e.g. https://www.openfoam.com/documentati...irfoil-2d.html Where exactly are you getting stuck? Do you want to start running simulation of potentiaFoam (easier to obtain convergence) Last edited by dlahaye; January 21, 2024 at 05:30. Reason: Added info |
Tommy Nee
Hi!
Thanks so much for getting back to me and very sorry for not responding quicker. I think I may have solved my issue so I completely forgot to check the thread again. Thanks and apologies again! |
ONESP-RO
Rep Power: 5 ![]() |
Please consider including the solution you found, as it could help others facing similar issues.
Don't keep making the same mistakes. Try to make new mistakes. |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
Biconvex Airfoil in incompressible flow | Courant | Main CFD Forum | 5 | February 27, 2011 16:45 |
literatures for Natural Laminar Flow airfoil | fxzf | Main CFD Forum | 0 | May 24, 2010 06:49 |
incompressible airfoil simualtion | vyom | FLUENT | 5 | September 20, 2005 20:50 |
Airfoil: Laminar or Turbulent | Yap Wen Jiun | Main CFD Forum | 3 | March 12, 2000 11:31 |
