January 12, 2024, 15:24 |
new problem with chtMultiRegion case
Alan w
Rep Power: 6 |
Like Odysseus, when finally in sight of Ithica, once more gets swept out to sea, I am having a new problem with my chtMultiRegion case,
after having assured myself that it was under control. Although it runs, I checked the streamlines to characterize the flow through the duct, and found that it is all wrong. This is maddening, since my test case, consisting of a block with a hole containing a radiator, works properly. In it, the streamlines run nicely through the flow path, as seen in attachment 1. But when I substitute in a fuselage with a radiator fairing, leaving everything else the same, the streamlines have a mind of their own, and make no sense, as can be seen in attachment 2. I know there are those who will say 'you have a bad surface geometry', but when I use the same fuselage body in a simpleFoam case, the streamlines look much better, as shown in attachment 3. I suspect the problem has something to do with coupling between the fluid (airflow) and solid (the radiator) regions; one place where this is controlled is in constant/fluid/fvOptions and constant/solid/fvOptions. In these, there are two options for interpolationMethod, and I have tried both of them, but the streamlines are still bad: Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // fluidTosolid { type constantHeatTransfer; interpolationMethod cellVolumeWeight; //interpolationMethod mapNearest; nbrRegionName solid; master false; nbrModel solidTofluid; fields (h); semiImplicit no; } porosityBlockage { type interRegionExplicitPorositySource; interRegionExplicitPorositySourceCoeffs { //interpolationMethod cellVolumeWeight; interpolationMethod mapNearest; nbrRegionName solid; type DarcyForchheimer; // D 100; // Very little blockage // D 200; // Some blockage but steady flow // D 500; // Slight waviness in the far wake // D 1000; // Fully shedding behavior d (20 20 20); // (120 100 100) f (20 20 20); // (120 100 100) coordinateSystem { type cartesian; origin (0 0 0); coordinateRotation { /*type axesRotation; e1 (0.5 0 0.866025); e2 (0 1 0);*/ type axesRotation; e1 (0 1 0); e2 (0 0 1); } } } } limitT { type limitTemperature; active yes; selectionMode all; min 10; max 700; } // ************************************************************************* // What baffles me is that the test case works, but the real world case does not, when the setup is identical. And, the geometry seems to be okay, as it works properly in a simpleFoam case. Once again, I am hoping that the community, with people far smarter than me, can help me resolve this. I have put a zip file of the case in my Dropbox account; here is the link: https://www.dropbox.com/scl/fi/9fzjx...9dlvtxpt6&dl=0 |
Problem with starting parallel case in OpenFOAM 11 | cececerece | OpenFOAM Running, Solving & CFD | 2 | November 25, 2023 12:31 |
continuing problem with chtMultiRegion case - need help | boffin5 | OpenFOAM Running, Solving & CFD | 7 | May 23, 2023 14:52 |
cannot get chtMultiRegion case to work | boffin5 | OpenFOAM Running, Solving & CFD | 11 | May 16, 2022 16:28 |
A problem in a Fluent case after I created the interface | ama294 | Fluent UDF and Scheme Programming | 0 | January 30, 2018 00:32 |
Problem running movingCylinders case in parallel with foam-extend-3.1 | mhkenergy | OpenFOAM Running, Solving & CFD | 5 | March 3, 2017 06:20 |
