Temperature oscillations/overshoots with buoyantFoam
Old   January 12, 2024, 03:34
Default Temperature oscillations/overshoots with buoyantFoam
oswald is on a distinguished road
Dear fellow foamers,
I am trying to simulate Rayleigh-Bénard-cells with buoyantFoam. Most things work quite well, but I get a strange temperature behaviour in a tiny region at one edge of the domain. Please have a look at the attached image. While top and bottom temperatures are 282 K and 294 K, respectively, in this small region the min and max temperatures reach ~280.9 K and 298.4 K. Does anyone have an idea, what could cause this behaviour? I also attached the relevant case files as an archive.
In this case, the walls are assumed to be adiabatic, so a zeroGradient condition is used for temperature. All the other BCs are more or less standard wall BCs.
Please fell free to ask, if something is unclear.
Best,
oswald
oswald is offline   Reply With Quote
Old   January 15, 2024, 05:14
I think I found a solution. As mentioned in other threads, it was not a good idea to put the pRefCell for pRef at a boundary. Using an internal cell or point solved the problem for me.
Edit: It only moved the problem to the inside of the domain. Using "perfectGas" for the equationOfState was the better solution.
Shadow Wall and temperature norger FLUENT 10 September 28, 2019 12:43
heat transfer coefficient value in floefd jason kid FloEFD, FloWorks & FloTHERM 10 October 16, 2016 17:55
Static temperature and Total temperature Jong-Yoon FLUENT 0 September 25, 2016 02:42
How to get free stream temperature in boundary condition saharesobh FLUENT 0 October 9, 2012 18:12
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 18:31
