Timothy
Rep Power: 3 ![]() |
Using buoyantSimpleFoam and the fvDOM model for radiation, I was trying to model a wall that received an external heat flux and external radiative heat flux. I applied the external wall heat flux BC for temperature: type externalWallHeatFluxTemperature; mode coefficient; h 4.76; Ta 306; kappaMethod fluidThermo; qr qr; For radiative intensity I, I used the grey diffusive condition with an external incident radiation type greyDiffusiveRadiation; qRadExt 350; The results were really weird, however. The wall temperature, which was initially at 306k, decreased significantly despite there being incident radiation. The results looked much better when I omitted the qr term from the temperature BC. The results also looked a lot better when I created a file for qr in the 0 folder and applied this BC meant for the viewFactor model type greyDiffusiveRadiationViewFactor; qro 350; Nevertheless, I was wondering if this was the right way of modelling an external radiative flux. Also, if I leave the qr BC in but remove the qRadExt from the IDefault BC, it becomes as though there was no external radiative flux at all. Thank you |
Timothy
Also, I was wondering the difference between applying an external heat flux at a wall as opposed to applying an external radiative flux at a wall. I.e.,
Case 1: For temperature, type externalWallHeatFluxTemperature; mode flux; q 350; kappaMethod fluidThermo; Case 2: (Using FvDOM) For radiative intensity I, type greyDiffusiveRadiation; qRadExt 350; The results I get are very different. For case 1, temperatures can increase by up to 50K. For case 2, the temperature does not increase by more than 3-4K |
buoyantsimplefoam, radiation fvdom, radiative heat flux |
Difference between External and Internal flow radiation problems | Kummi | FLUENT | 0 | April 10, 2018 03:06 |
Fluent Radiation/porous media | Schmitt pierre-Louis | FLUENT | 26 | September 1, 2016 10:29 |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 05:41 |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 01:40 |
Fluent incident radiation problem | Michael Schwarz | Main CFD Forum | 0 | October 21, 1999 05:56 |
