Flow rate at Non Conformal Coupling Interfaces
Old   January 11, 2024, 13:33
Default Flow rate at Non Conformal Coupling Interfaces
Pedro Gouveia
unilord is on a distinguished road
Hey Guys
I am performing a centrifugal pump CFD analysis in OpenFoam 11 (where there is no more AMI, and they use NCC instead) and I am facing some problems in residuals. They do not go below 10^-3 for pressure. However, when comparing the data with the experiment from a scientific paper, the head (pressure in outlet - pressure in inlet) is below 3% error.
I wondered what was happening and inserted a flow rate probe in the NCC interfaces. I saw that, in outlet and inlet, the flow rate is 0.0063 m^3/s, which is the supposed. However, in NCC interfaces, it behaves like this:
NCC1_2 - Positive and negative values, ranging from e-27 to e-28
NCC2_1 - Same negative value, 7.935464e-14
NCC2_3 - Same positive value, 1.197136e-18
NCC3_2 - Positive and negative values, ranging from e-34 to e-35
The interfaces are curved. Can someone help me on this?
unilord is offline   Reply With Quote
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate MSchneid Fluent UDF and Scheme Programming 3 February 23, 2019 07:00
actual flow rate not match the designed flow rate in ventilation modeling minecraftgp OpenFOAM Running, Solving & CFD 2 November 18, 2018 13:37
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 11:30
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 14:14
Discrete Phase & Mass Flow Rate MagnusZeus FLUENT 0 December 2, 2011 18:57
