divergence prob - Rotating disk in the cavity with inlet and outlet |
January 11, 2024, 05:19 |
Hi, everyone.
I'm a newer to OpenFoam. I want to simulate the flow of one rotating disk in the cavity with inlet and outlet. Firstly, the simulation using icoFoam solver with laminar nonrotating case is ok . But when I give the rotating speed by using the rotatingWallVelocity, the code doesn't work. The error is "Floating point exception" . I think it should not be due to the mesh, because I can get the results with ANSYS Fluent. Here's my code. Can anyone give me some advices? ::::::::::::::::: file:::::::::::::::::::::::: dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { INLET { type zeroGradient; } OUTLET { type fixedValue; value $internalField; } ROTOR { type zeroGradient; } STATOR { type zeroGradient; } } ::::::::::::::::::U file:::::::::::::::::::::::: dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { INLET { type fixedValue; value uniform (-0.283 0 0); } OUTLET { type zeroGradient; } ROTOR { type rotatingWallVelocity; origin (0 0 0); axis (1 0 0); omega 262; } STATOR { type noSlip; } } Last edited by Igor GAO; January 11, 2024 at 05:24. Reason: adding extra information |
[OLAFLOW] The OLAFLOW Thread | Phicau | OpenFOAM Community Contributions | 459 | September 12, 2024 12:47 |
interFoam: defining boundary conditions (at inlet and outlet) based on water heights | atul1018 | OpenFOAM Running, Solving & CFD | 0 | January 2, 2024 10:31 |
[waves2Foam] Initial water level is not horizontal, but U shaped towards domain inlet and outlet | noodleluvmay | OpenFOAM Community Contributions | 2 | April 27, 2023 13:24 |
boundary condition for coupled inlet and outlet | xxxx | OpenFOAM Pre-Processing | 2 | August 13, 2013 16:51 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 09:07 |
