Difficulties with chtMultiRegionTwoPhasesEulerFoam
Old   December 29, 2023, 02:25
Default Difficulties with chtMultiRegionTwoPhasesEulerFoam
Goind Sharma
govind_IITD is on a distinguished road
I am using chtMultiRegionTwoPhaseEulerFoam to simulate problem for flow through a channel with side walls having thickness, which takes into account of conjugate heat transfer. In this case, liquid enters with phase fraction 1 and gas with 0 phase fraction and upon the course of simulation liquid must vaporize from the two sides, physically.
However, this doesn't happen actually. It seems to be note that flow field is looking okay but not the distribution of phase fraction.
I have attached three screenshots: the first one (temperature field of both fluid and solid), second one (gas phase fraction with solid temperature), and third one (fluid velocity with solid temperature).
Please suggest me some modeling aspects for chtMultiRegionTwoPhaseEulerFoam so that I can rectify it.
Otherthing, that I am worried about the usage of iDmdt in relaxationFactor sub-dictionary.
Regards,
Govind
govind_IITD is offline   Reply With Quote
Old   May 2, 2024, 11:06
Oscar Zagal
oscar_zagal is on a distinguished road
Hello there
With respect the distribution of volume fraction it depends strongly on the flow rate, if is slow and gravity is set in -y direction stratification occurs just like your case.
I have a question for you, do you know the governing equations of this solver?
Thanks in advance.
oscar_zagal is offline   Reply With Quote
Old   May 7, 2024, 05:17
Goind Sharma
Thanks.
Actually, I came up with the reasoning.
Could please tell me about "iDmdt"? or any reference where I can get the info about this.
Regards,
Govind
Old   May 7, 2024, 11:39
Oscar Zagal
I am also stuck with that, is very difficult to read the source code as well, if i get some new information i will tell you.
Old   May 10, 2024, 08:37
Goind Sharma
Thanks. Actually, this solver has lot of promising applications.
Old   May 14, 2024, 17:13
Oscar Zagal
Hi there again
I found some new information about the terms you asked: iDmdt and wDmdt, they are called interfacial mass transfer and boundary mass transfer respectively, you can see a mathematical formula since the line 417 of this link: https://www.openfoam.com/documentati...ce.html#l00056
Is part of the source code
Regards
Oscar
Old   May 21, 2024, 07:29
Goind Sharma
Thanks Oscar. Its quite helpful for my understanding.
Difficulties calculating the areas of intersections between elements and a cut plane jafy EnSight 0 March 7, 2022 07:08
Having difficulties in getting water to boil jigneshrohit99 Fluent Multiphase 2 April 5, 2016 13:06
Convergence difficulties vgrzv FLUENT 2 December 2, 2015 12:06
Difficulties with Cd agreement! A.D.E Main CFD Forum 3 July 13, 2011 14:22
Difficulties in solving a high Reynolds number Flow? wowakai Main CFD Forum 10 December 29, 1998 13:46
