How to combine convection and heat flux BC?
Old   December 21, 2023, 11:06
Default How to combine convection and heat flux BC?
nicolas Claverie
dynalo is on a distinguished road
I want to simulate a solid sphere in open air receiving a constant heat flux.
Basically the BC of my sphere should be a combination of
air_to_sphere
type externalWallHeatFluxTemperature;
mode power;
Q uniform 5; // 5 W received on the boundary
kappaMethod solidThermo;
value uniform 300;
for the constant heat flux, and
air_to_sphere
type compressible::turbulentTemperatureRadCoupledMixed;
Tnbr T;
value uniform 314;
For the convection.
Is there a way to do that?
One option would be to add a constant radiation flux on the sphere but I never used radiation in a model so I am not very confortable to do that.
PS: install information if relevant:
Windows 11 pro 22H2
WSL 2.0.9.0
Ubuntu 22.04.3 LTS
Openfoam 2306
dynalo is offline   Reply With Quote
Old   December 21, 2023, 14:00
Tobermory will become famous soon enough
You want to specify both the heat flux and the HTC, without any radiation present? Surely this is over-specifying the boundary condition?
And what do you mean by "convection" ... it can't be the usual meaning, i.e. convection to the fluid inside the domain, since you are already specifying the heat flux (which will in turn define the boundary surface temperature) ... and the only way the code could achieve this would be to set both the boundary temperature and the cell temperature, which is not allowed.
If you mean "conduction" through the wall, rather than "convection", i.e. set an external surface temperature and a heat transfer coeff thru the wall, then this is over-constrained & impossible to implement.
So I am a bit puzzled my friend as to what you are trying to achieve. It doesn't sound physical. Ofc, I may have misunderstood ...
Tobermory is offline   Reply With Quote
boundaries condition, convection, heat transfer, openfoam
Time alternating Convection and Heat flux BC jchan033 Fluent UDF and Scheme Programming 5 December 24, 2016 02:14
Heat flux with convection and radiation loss kcgmech Fluent UDF and Scheme Programming 0 February 11, 2016 05:08
convection + known heat flux BC in the same wall zfaraday OpenFOAM 0 November 19, 2013 17:01
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Natural convection with heat flux Anton FLUENT 5 April 2, 2007 05:03
