Setting restraints in dynamicMeshDict
Old   December 20, 2023, 05:34
Default Setting restraints in dynamicMeshDict
stBern is on a distinguished road
Hello everyone,
This is probably a trivial question but here it goes...
In DTCHullMoving tutorial there are some restraints on the hull.
restraints
    translationDamper
        type linearDamper;
        body hull;
        coeff 8596;
    rotationDamper
        type sphericalAngularDamper;
        body hull;
        coeff 11586;
How are they defined? Which calculations are involved in setting these parameters?
stBern is offline   Reply With Quote
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 06:08
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Warning 097- AB Siemens 6 November 15, 2004 04:41
