rhoPimpleFoam solver,Error Negative initial temperature T0: -105.8
Old   December 12, 2023, 23:47
Unhappy rhoPimpleFoam solver,Error Negative initial temperature T0: -105.8
hanbin
loopbing is on a distinguished road
My case of flow around a cylinder can only run 0.003 time steps, and I want it to complete the 0.3s or even longer. I have tried to reduce the time steps, increase the mesh density, reduce the Courant number, and reduce the relaxation factor, all of which can only comparatively lengthen the running time.
loopbing is offline   Reply With Quote
rhopimplefoam
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 15:26
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 13:50
