December 11, 2023, 13:00 |
buoyantboussinesqpimplefoam
Ragav
Rep Power: 3 |
Below are the boundary condition I have given to a buoyantBoussinesqSimpleFoam problem. I am getting the following error -
Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 3.52534 Specified mass inflow : 0.03 Specified mass outflow : 0 Adjustable mass outflow : 0 Please check and see where the error is? FoamFile { version 2.0; format ascii; class volScalarField; object alphat; //turbulent thermal diffusivity } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { Inlet { type zeroGradient; } outlet { type zeroGradient; } cylwall { type alphatJayatillekeWallFunction; Prt 0.85; value uniform 0; } sqwall { type alphatJayatillekeWallFunction; Prt 0.85; value uniform 0; } } FoamFile { version 2.0; format ascii; class volScalarField; object epsilon; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -3 0 0 0 0]; internalField uniform 0.3; boundaryField { Inlet { type turbulentMixingLengthDissipationRateInlet; mixingLength 0.0035; //a good estimation is 0.07*characteristic_length value uniform 0.3; } outlet { type zeroGradient; } cylwall { type epsilonWallFunction; value $internalField; } sqwall { type epsilonWallFunction; value $internalField; } } FoamFile { version 2.0; format ascii; class volScalarField; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.034; boundaryField { Inlet { type turbulentIntensityKineticEnergyInlet; intensity 0.0505;//turbulence intensity value uniform 0.034; } outlet { type zeroGradient; } cylwall { type kqRWallFunction; value $internalField; } sqwall { type kqRWallFunction; value $internalField; } } FoamFile { version 2.0; format ascii; class volScalarField; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { Inlet { type calculated; value uniform 0; } outlet { type calculated; value uniform 0; } cylwall { type nutkWallFunction; value uniform 0; } sqwall { type nutkWallFunction; value uniform 0; } } FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 1e5; boundaryField { Inlet { type fixedFluxPressure; value uniform 1e5; } outlet { type fixedValue; value uniform 1e5; } cylwall { type fixedFluxPressure; value uniform 1e5; } sqwall { type fixedFluxPressure; value uniform 1e5; } } FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { Inlet { type fixedFluxPressure; rho rhok; value uniform 0; } outlet { type fixedFluxPressure; rho rhok; value uniform 0; } cylwall { type fixedFluxPressure; rho rhok; value uniform 0; } sqwall { type fixedFluxPressure; rho rhok; value uniform 0; } } FoamFile { version 2.0; format ascii; class volScalarField; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 300; boundaryField { Inlet { type zeroGradient; } outlet { type zeroGradient; } sqwall { type zeroGradient; } cylwall { type fixedValue; value uniform 500; } } FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { Inlet { type fixedValue; value uniform (0 3.0 0); } outlet { type zeroGradient; //value uniform (0 0 0); } cylwall { type noSlip; } sqwall { type noSlip; } } |
December 12, 2023, 04:30 |
Yann
Rep Power: 29 |
I'm not sure this is the only problem in your setup, but with solvers using p_rgh variable, you need to define pressure boundary conditions on p_rgh and use the calculated boundary condition on p. Have a look at the tutorials to have examples. Also your message is very hard to read, please use [CODE] blocks to post files contents. Regards, Yann Last edited by Yann; December 12, 2023 at 12:46. Reason: typo |
December 12, 2023, 12:42 |
#3 | |
Ragav
Rep Power: 3 |
buoyantboussinesqsf |
