interFOAM air_water interface strange behaviour |
Anurag
Rep Power: 3 ![]() |
Hi I have modeled partially filled flow in a pipe as shown, but when the water strikes the floor, it breaks the surface and it shows strange behaviour. I have reduced the timestep and Co and also refined the mesh but it causes no change in results. Do I need to change anything in fvSchemes? or something else. Because in fluent the same problem, the air-water interface is coming perfectly smooth. I attached the picture.
Thanks |
Michael Sukham
Rep Power: 6 ![]() |
What are the fvScheme and fvSolution? I guess solver is interFoam.
#3 | |
Anurag
fvSolution=alphawater=smoothsolver, pcorr=PCG, p_rgh=GAMG, PIMPLE=momentum predictor=no. Do I have to choose any other schemes? |
Michael Sukham
Maybe its the interface compression. cAlpha in PIMPLE/PISO parameter in case of foamExtend or alpha.water in fvSolutions where the compression factor is given. try 0 and try 1 (there are reports where higher cAlpha results in oscillations). Although cAlpha = 0 would give a diffused alpha field, that would be a start to your problem.
Anurag
I tried with calpha =1 but it is same but I will try with calpha=0. Do you think that it is something to do with schemes? of div U or alpha or something with the MULES setting in alphawater? Thanks |
Michael Sukham
Try running with the dam break case settings provided.Your schemes seem fine. Which version are you using? The simulation doesn't seem that heavy so maybe I can try running in my machine and see it.
With regards Last edited by 2538sukham; December 15, 2023 at 04:33. |
Anurag
Yea i am using OpenFOAM-7. Yea i have tried damBreak settings although I will try again. I tried attaching mesh but it is very large. I am writing the BCs for you. Inlet-just water inlet with some flow rate, Mass flow rate=3.3, Outlet pressure outlet, and walls no slip. I have used similar BCs as angledDuct in the tutorials within interFOAM but with only inlet, outlet and walls for different components like velocity, alpha.water, etc. If you need any details please ask me. I can share the zip with you email if yu want. Thanks. |
Anurag
What i am noticing is when the water falls from the height it causes some air-water interface problems, but when it just flows thru a pipe it is coming smooth.
#9 |
Michael Sukham
I am at a lost, but then try curving the geometry at the junction, instead of a sharp 90 degree turn.
interFoam: strange doplet behaviour at mesh transition | geth03 | OpenFOAM Running, Solving & CFD | 3 | December 17, 2023 11:16 |
Calculation of interface area interFoam / VoF | überschwupper | OpenFOAM Programming & Development | 18 | August 19, 2022 11:03 |
How to use the CFX periodic interface | zhihuawan | CFX | 61 | January 15, 2018 16:20 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
