interFoam: strange doplet behaviour at mesh transition |
Rep Power: 8 ![]() |
i am trying to simulate droplets moving on a 2D-plane,
bc of geometry my cells transition at certain points, see pic1. right at the transition point, the lighter droplets are dragged down. compare pic 2 und 3, before and after photos. i draw a circle around one droplet to compare the two states. that happens to all droplets but smaller droplets are carried more aggressively. any help is appreciated. |
i tried various things already without success:
1. mesh refinement: i used the same meshing style but with much finer cells 2. changed meshing strategy completely with tet-mesh and unstructured hex mesh: there are droplets now that stay in place and don't move, they just wiggle around like the one in the 2 screenshots. |
Anurag
Rep Power: 3 ![]() |
i think due to momentum of the carrier fluid smaller droplets are affected more because they are lighter. Are the droplets moving inside a liquid?
i played around with the numerics and solved it.
of course the carrier fluid has an impact, but the mesh transition and standard numerics lead to that unphysical flow behaviour. |
flow over cylinder in openFoam | saeed jamshidi | OpenFOAM Pre-Processing | 3 | August 11, 2023 15:16 |
Different behaviour of interFoam across versions | mrishi | OpenFOAM Running, Solving & CFD | 1 | June 10, 2022 18:32 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
strange pressure behaviour with symmetricPlane boudary condition - interFoam | duongquaphim | OpenFOAM Running, Solving & CFD | 10 | August 20, 2013 14:00 |
