Save the InitialResidual as a variable in personalized solver
Old   December 1, 2023, 12:35
Default Save the InitialResidual as a variable in personalized solver
Martin Marone
MaroneM is on a distinguished road
Hi everyone!
I am wondering how can I save the "Initial residual" reported by the different OpenFOAM numerical solvers as a variable that then I can use for example to define the convergence criteria for a system of partial differential Eq. In particular I am now interested in the momentum equation (UEqn.H), which I am taking from OpenFOAM's native "buoyantBoussinesqSimpleFoam" implementation, which I present bellow:
    MRF.correctBoundaryVelocity(U);
    tmp<fvVectorMatrix> tUEqn
        fvm::div(phi, U)
      + MRF.DDt(U)
      + turbulence->divDevReff(U)
        fvOptions(U)
    fvVectorMatrix& UEqn = tUEqn.ref();
    UEqn.relax();
    fvOptions.constrain(UEqn);
    if (simple.momentumPredictor())
        solve
            UEqn
            fvc::reconstruct
                  - ghf*fvc::snGrad(rhok)
                  - fvc::snGrad(p_rgh)
                )*mesh.magSf()
        fvOptions.correct(U);
I would like to do something more or less like the following:
scalar initResUx = yourSolutionHere;
scalar initResUy = yourSolutionHere;
scalar initResUz = yourSolutionHere;
scalar initResUEqn = initResUx+initResUy+initResUz;
Thank you in advance! ^^
MaroneM is offline   Reply With Quote
residual, ueqn
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate Kieyo Fluent Multiphase 0 November 10, 2022 00:58
two different gas! Fluid pair model! saha2122 CFX 7 February 9, 2022 08:15
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
Solver with variable viscosity wildfire230 OpenFOAM Running, Solving & CFD 3 May 22, 2018 09:09
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
