Initialise RSM using SST K-Omega Precursor Simulation
Old   December 1, 2023, 07:27
Default Initialise RSM using SST K-Omega Precursor Simulation
ASR
sr786 is on a distinguished road
I am running a steady state case for single phase flow (water) in a stirred tank reactor (no baffles) agitated by a magnetic rod stirrer lying on the reactor base. The top of the tank is open (slip BC).
I have managed to perform a run using two equation model (SST K-Omega) and the results are well converged and the simulation is nice and stable.
Now I want to use the SST K-Omega results to initialise an RSM run. I have already computed R (and epsilon) using the postProcess utility.
However, when I try to run RSM the simulation keeps blowing up within the first few iterations and I cannot understand why.
If anyone is experienced with running RSM in OpenFOAM could I please ask for your advice in set in RSM set-up as I am completely stuck.
sr786 is offline   Reply With Quote
Old   December 1, 2023, 11:43
Domenico Lahaye
dlahaye is on a distinguished road
simpleFoam tutorial PitzDaily using Reynolds stress tensor (LRR RASModel)
Smaller relaxation factors?
dlahaye is offline   Reply With Quote
RSM Stress Omega effect on Torque Prediction cbooks77 FLUENT 2 October 4, 2021 20:17
Weird result by k omega SST bingo641 OpenFOAM 3 May 28, 2018 00:05
Setting change from k omega to k omega SST bingo641 OpenFOAM Programming & Development 0 May 22, 2018 06:15
how to calculate the omega at inlet boundary in k omega sst Scabbard OpenFOAM Running, Solving & CFD 2 September 30, 2014 14:06
Boundary Conditions for k omega SST dancfd OpenFOAM Pre-Processing 0 June 10, 2011 00:25
