Singular Matrix Error
Old   November 30, 2023, 17:55
Default Singular Matrix Error
Jonathan
jd01930 is on a distinguished road
Hello all,
I am running a simulation of a Backwards Facing Step Combustor using ReactingFoam solver. Gas species prescribed at beginning of simulation are CH4, O2, N2,
I am trying to ignite it via energy injection using constant/fvOptions file and topoSet function in OpenFOAM-5.x. I initialized the flow field without energy injection and let the flow field with different gas species develop before turning on chemistry and reactions.
Recently I have been running it and after the energy injection is added it slowly climbs in temperature because I decreased my deltaT to 1e-7 seconds.
Energy injection begins at t=0.285 s at a level of h = 5e8 kg/m/s^3. It is supposed to inject energy until t=0.288 s.
The simulation continues to run satisfactory until t = 0.2861204 seconds.
There is no crazy spike in iterations calculated for U velocity. In the output it just says "Application 45971293 exit codes: 134
Application 45971293 exit signals: Killed
Application 45971293 resources: utime ~579s, stime ~153s, Rss ~129344, inblocks ~621642, outblocks ~0
Then the error file says. "FOAM FATAL ERROR: Singular matrix
From function void Foam::LUDecompose(Foam::scalarSquareMatrix&,
Foam::labelList&, Foam::label&)
in file matrices/scalarMatrices/scalarMatrices.C at line 69.
I am wondering what the reason would be for this Singular matrix error that happens all of a sudden after running this for many thousands of timesteps. I have seen other forum posts where people have said that they would change their solvers in fvSolutions, but I am not sure how or why I would need to change this.
Any help is appreciated.
jd01930 is offline   Reply With Quote
Old   January 10, 2024, 03:50
Swirl is on a distinguished road
Hi, were you able to solve this issue? I am currently running into the same error. Thanks in advance!
Swirl is offline   Reply With Quote
bfs, combustion, ignition, openfoam, reactingfoam
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
