Simulating VoF with NNC and AMR in openFoam
Old   November 28, 2023, 16:45
Post Simulating VoF with NNC and AMR in openFoam
Axel Schubert
Chuffa is on a distinguished road
Hi, I'm currently working on simulating Volume of Fluid (VoF) in OpenFOAM using NonConformal Coupling (NCC). However, I've run into a roadblock with the following error:
--> FOAM FATAL ERROR:
The start face is not defined for a nonConformal patch with a non-zero number of faces
    From function virtual Foam::label Foam::nonConformalFvPatch::start() const
    in file fvMesh/fvPatches/constraint/nonConformal/nonConformalFvPatch.C at line 98.
FOAM exiting
This error occurs when I use MPLIC for div(phi,alpha) in my fvSchemes, everything works well with interfaceCompression.
The thing is I can't employ Adaptive Mesh Refinement (AMR) with interfaceCompression.
Has anyone encountered a similar issue or have insights into resolving this?
Thank you for your help!
Chuffa is offline   Reply With Quote
Old   November 29, 2023, 09:42
Wowbagger's Avatar
Michael S.
Wowbagger is on a distinguished road
Send a message via Skype™ to Wowbagger
Hi Chuffa,
see the answer from Jan in this thread, NCC and PLIC/MPLIC is not compatible:
PLIC and 2-1 constraint
Best regards Michael
Wowbagger is offline   Reply With Quote
adaptive mesh refinement, nonconformal, volume of fluid
Simulating VoF with NNC and AMR in openFoam Chuffa Main CFD Forum 0 November 28, 2023 14:00
