Non spherical drag force - possible wrong particle volume
Old   November 28, 2023, 13:06
Default Non spherical drag force - possible wrong particle volume
anonymous
fkop is on a distinguished road
I have been using icoUncoupledKinematicParcelFoam for simulating flow of a single particle, and have noticed that the solver calculates the volume of a particle by using the formula for the volume of a sphere, i.e. 4/3 * pi * (d/2)³.
For example, for a diameter of 3 mm the volume would be equal to 1.41e-8 m³, which is what I get in the output file.
However, when choosing a nonSphereDragForce model, the volume remains the same, even though the particle shouldn't be a sphere anymore. Am I correct in thinking that the modelled particle behavior is then wrong, considering that a non spherical particle should have a different volume than a spherical one? Is there maybe a way to change how the volume is calculated?
Thanks for your help
fkop is offline   Reply With Quote
Calculating source term total cell-zone volume parallel computation RobV Fluent UDF and Scheme Programming 2 May 30, 2022 04:46
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 19:05
Force can not converge colopolo CFX 13 October 4, 2011 23:03
formula used for drag force? kamma Main CFD Forum 0 April 2, 2010 11:21
