Incorrect calculations of overset small-gap-multifloats
Old   November 25, 2023, 04:31
Default Incorrect calculations of overset small-gap-multifloats
Tianyuan Wang
hachikoi is on a distinguished road
I recently used OF to simulate a coaxial double-float device. The inner float does not move (it will move later, so it is made into an overset), the outer float initial displacement is -1m to do the free decay test.
The inner float overset is larger and wraps around the outer float overset.
The current calculations show that the outer floater has a negative velocity for the first few seconds, which is non-physical. Outer floater alone / inner floater alone / outer floater overset + inner floater background are all normal.
I tried to modify oversetInterpolation method, add oversetInterpolationSuppressed and oversetInterpolationRequired, add oversetAdjustPhi in PIMPLE, and modtify dynamicMeshDict. None of them work.
I'm assuming it's caused by overset interpolation. Could anyone give me some advice on it?
fvSchemes
| \\ / O peration | Version: v2306 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
divSchemes
div(rhoPhi,U) Gauss limitedLinearV 1;
div(U) Gauss linear;
div(phi,alpha) Gauss vanLeer;
div(phirb,alpha) Gauss linear;
div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,omega) Gauss upwind;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
method inverseDistance;
fluxRequired
default no;
p_rgh;
pcorr;
alpha.water;
wallDist
method meshWave;
//method Poisson;
grad(p_rgh);
surfaceIntegrate(phiHbyA);
k;
epsilon;
omega;
nut;
alpha.water;
// ************************************************** *********************** //[/CODE]
fvSolution
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSolution;
solvers
"cellDisplacement.*"
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
maxIter 100;
"alpha.water.*"
nAlphaCorr 2;
nAlphaSubCycles 1;
cAlpha 1;
icAlpha 0;
MULESCorr yes;
nLimiterIter 5;
alphaApplyPrevCorr no;
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-08;
relTol 0;
"pcorr.*"
solver PCG;
preconditioner DIC;
tolerance 1e-09;
relTol 0;
p_rgh
solver PBiCGStab;
preconditioner DILU;
tolerance 1e-09;
relTol 0.01;
p_rghFinal
$p_rgh;
relTol 0;
"(U|k|omega|epsilon).*"
tolerance 1e-08;
relTol 0;
yPsi
solver PBiCGStab;
tolerance 1e-6;
relTol 0.0;
yPsiFinal
$yPsi;
relTol 0;
PIMPLE
momentumPredictor no;
nOuterCorrectors 5;
nCorrectors 2;
nNonOrthogonalCorrectors 1;
ddtCorr yes;
correctPhi no;
moveMeshOuterCorrectors no;
turbOnFinalIterOnly no;
oversetAdjustPhi yes;
relaxationFactors
fields
equations
".*" 1;
cache
grad(U);
dynamicMeshDict
FoamFile
version 2.0;
format ascii;
class dictionary;
object dynamicMeshDict;
dynamicFvMesh dynamicOversetFvMesh;
solvers
dynamicPlatform
motionSolverLibs (libfvMotionSolvers);
motionSolver multiSolidBodyMotionSolver;
multiSolidBodyMotionSolverCoeffs
zonePlatform
solidBodyMotionFunction linearMotion;
linearMotionCoeffs
velocity (0 0 0);
dynamicWECMiddle
motionSolverLibs (librigidBodyMeshMotion);
motionSolver rigidBodyMotion;
report on;
cellSet cellWECMiddle;
cOfGdisplacement CofG;
bodyIdCofG 1;
solver
type Newmark;
accelerationRelaxation 0.8;
accelerationDamping 0.9;
nIter 3;
bodies
dynamicWECMiddle
type rigidBody;
parent root;
mass 2.0126e+06;
centreOfMass (0 0 0); // COG in the local coordinate system, based on transform
inertia (1.3312e+08 0 0 1.3312e+08 0 2.1384e+08); // (Ixx Ixy Ixz Iyy Iyz Izz)
transform (1 0 0 0 1 0 0 0 1) (0 0 -1);
joint
type Pz;
patches
WECMiddle
innerDistance 100;
outerDistance 101;
restraints
motionSolverLibs (sixDoFRigidBodyMotion);
motionSolver sixDoFRigidBodyMotion;
patches (WECMiddle);
innerDistance 100;
outerDistance 101;
centreOfMass (0 0 -1);
mass 2.0126e+06;
momentOfInertia (1.3312e+08 1.3312e+08 2.1384e+08);
report on;
solver
type Newmark;
constraints
zAxis
sixDoFRigidBodyMotionConstraint line;
direction (0 0 1);
0
FoamFile
version 2.0;
format ascii;
class volScalarField;
object alpha.water;
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
#includeEtc "caseDicts/setConstraintTypes"
inlet
type zeroGradient;
outlet
type zeroGradient;
"(rightSide|leftSide)"
type zeroGradient;
lowerSide
type zeroGradient;
atmosphere
type inletOutlet;
inletValue $internalField;
value $internalField;
oversetWECMiddle
type overset;
WECMiddle
type zeroGradient;
oversetPlatform
type overset;
platform
type zeroGradient;
FoamFile
version 2.0;
format ascii;
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
boundaryField
inlet
type fixedFluxPressure;
outlet
lowerSide
atmosphere
type totalPressure;
p0 $internalField;
oversetWECMiddle
type overset;
WECMiddle
oversetPlatform
type overset;
platform
FoamFile
version 2.0;
format ascii;
class pointVectorField;
object pointDisplacement;
dimensions [0 1 0 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
outlet
type fixedValue;
type fixedValue;
lowerSide
type fixedValue;
atmosphere
type fixedValue;
oversetWECMiddle
patchType overset;
type zeroGradient;
WECMiddle
type calculated;
oversetPlatform
patchType overset;
type zeroGradient;
platform
type fixedValue;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
boundaryField
inlet
type waveVelocity;
outlet
type waveVelocity;
type waveVelocity;
lowerSide
type fixedValue;
atmosphere
type pressureInletOutletVelocity;
oversetWECMiddle
type overset;
WECMiddle
type movingWallVelocity;
oversetPlatform
type overset;
platform
type fixedValue;
hachikoi is offline   Reply With Quote
Old   November 25, 2023, 08:23
Tianyuan Wang
Hello Dr. Tobias https://www.cfd-online.com/Forums/blogs/tobi/
Could you give me some help on this issue?
Many thanks
Tianyuan
Old   November 26, 2023, 14:03
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Sorry I am out of time no support therefore.
Tobi
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 04:15
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[snappyHexMesh] Meshing a small gap between walls staustrahltriebwerk OpenFOAM Meshing & Mesh Conversion 1 July 23, 2012 12:46
Compressible Flow through small gap Andreas FLUENT 0 May 19, 2006 11:11
turbulence model for oil flow thr' small gap carno Siemens 2 August 31, 2005 09:12
