Problem with starting parallel case in OpenFOAM 11 |
#1 | |
Ilia Khristoforov
Rep Power: 2 ![]() |
Hi Everyone!
I am trying to run parallel case in OpenFOAM 11 on WSL2. I have 8 cores, however, I want to run the case on 6 cores. The code can be found here. DecomposeParDict seems correct, and the case without it is working perfectly fine. Also, all the checks stated in the OpenFOAM tutorial are done and MPI is enabled. When I try to run mpirun -np 6 foamRun -parallel, I get following traceback: Quote:
Ilia Khristoforov
Unfortunately, the problem was with WSL. I tried to run the case on Ubuntu and it worked
Yann
Rep Power: 27 ![]() |
I just tried out of curiosity, and it works for me. OpenFOAM-11 on WSL2 running Ubuntu 20.04. Not sure what is wrong for you, but I thought you might want to know it is supposed to work. Yann |
openfoam 11, parallel, parallel decomposepar |
Problem with parallel run on OpenFoam | stater | OpenFOAM Running, Solving & CFD | 0 | March 15, 2023 09:05 |
what is problem my OpenFoam setting? | Lee97 | Main CFD Forum | 0 | September 1, 2022 08:57 |
Problem running OpenFOAM 2.2.x in parallel in Centos 5 | lvalvare | OpenFOAM Running, Solving & CFD | 33 | December 9, 2020 08:44 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 05:40 |
Something weird encountered when running OpenFOAM in parallel on multiple nodes | xpqiu | OpenFOAM Running, Solving & CFD | 2 | May 2, 2013 04:59 |
