rhoPimpleFoam Error: cannot be called for a calculatedFvPatchField on patch |
April 4, 2024, 04:39 |
#21 |
Yann
Rep Power: 29 |
Hello Mohd Shaeq,
There is indeed some bad math happening, and it seems related to the turbulence model (according to the error message mentioning it, and the fact the error happens when the solver tries to solve epsilon) This could be caused by different things: boundary conditions, numerical setup, maybe mesh, ... Regarding your second issue, I am not familiar with the processes you are simulating so I am not sure I can help. How is penetration length defined for liquids and gases? Regards, Yann |
April 4, 2024, 12:30 |
rhoReactingFoam works for a period of time
#22 |
Mohd Shaeq
Rep Power: 3 |
Hello Yann,
I was able to make rhoReactingFoam run by making changes to the temperature boundary condition. I made a comparison for two turbulence models, viz. RAS and LES. The simulation ran a lot faster for LES in comparison to RAS. What could be the reason for this? After running smoothly and steadily for the first 38 timesteps, the simulation crashes, however, in the 39th one with the following error:- Code:
Courant Number mean: 5.99255e-05 max: 120.942 Time = 3.9e-06 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 0.0237574, Final residual = 0.00161816, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.00593231, Final residual = 0.000405769, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 9.06636e-06, Final residual = 3.77099e-07, No Iterations 2 [5] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [5] #1 Foam::sigFpe::sigHandler(int) at ??:? [5] #2 ? in /lib64/libc.so.6 [5] #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? [5] #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:? [5] #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? [5] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? [5] #7 Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:? [5] #8 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? [5] #9 ? at ??:? [5] #10 __libc_start_main in /lib64/libc.so.6 [5] #11 ? at ??:? [iflw019:1272589:0:1272589] Caught signal 8 (Floating point exception: tkill(2) or tgkill(2)) ==== backtrace (tid:1272589) ==== 0 /lib64/libucs.so.0(ucs_handle_error+0x2dc) [0x7efd92658e4c] 1 /lib64/libucs.so.0(+0x2c02c) [0x7efd9265902c] 2 /lib64/libucs.so.0(+0x2c2da) [0x7efd926592da] 3 /lib64/libc.so.6(gsignal+0x10f) [0x7efdaf568acf] 4 /opt/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam22symGaussSeidelSmoother6smoothERKNS_4wordERNS_5FieldIdEERKNS_9lduMatrixERKS5_RKNS_10FieldFieldIS4_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEEhi+0x2ed) [0x7efdb0a0c82d] 5 /opt/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam22symGaussSeidelSmoother6smoothERNS_5FieldIdEERKS2_hi+0x3b) [0x7efdb0a0ca7b] 6 /opt/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam12smoothSolver5solveERNS_5FieldIdEERKS2_h+0x641) [0x7efdb0a011f1] 7 /opt/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x178) [0x7efdb7422e28] 8 /opt/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x37d) [0x7efdb6d8ca0d] 9 /opt/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0xf) [0x7efdb6d35bbf] 10 rhoReactingFoam() [0x433ada] 11 /lib64/libc.so.6(__libc_start_main+0xe5) [0x7efdaf554d85] 12 rhoReactingFoam() [0x439e4e] The fvSolution file is as follows:- Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; smoother GaussSeidel; tolerance 1e-6; relTol 0.01; } pFinal { $p; relTol 0; } "pcorr.*" { $p; tolerance 1e-2; relTol 0; } "(rho|U|h|k|epsilon|omega|Yi)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-06; relTol 0.1; } "(rho|U|h|k|epsilon|omega|Yi)Final" { $U; relTol 0; } } PIMPLE { momentumPredictor yes; transonic no; nOuterCorrectors 3; nCorrectors 1; nNonOrthogonalCorrectors 0; pMaxFactor 1.2; pMinFactor 0.8; } relaxationFactors { equations { "(U|h|k|epsilon|omega).*" 1; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default cellLimited Gauss linear 0.5; grad(U) faceLimited Gauss linear 0.5; } divSchemes { default none; div(phi,U) Gauss linearUpwind grad(U); div(phi,h) Gauss linearUpwind grad(h); div(phi,K) Gauss linear; div(meshPhi,p) Gauss linear; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; div(phi,Yi_h) Gauss upwind; } laplacianSchemes { default Gauss linear limited 0.5; //default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default limited 0.5; //default corrected; } // ************************************************************************* // Liquid Penetration Length: The distance travelled axially from 95 % of the mass fraction of the liquid phase from the exit of the nozzle. Vapour Penetration Length: The distance traveled axially from 0.1 % of the mass fraction of the vapour phase, originated by the evaporation of the liquid phase injected, from the exit of the nozzle. Kind regards, Mohd Shaeq |
Problem with cyclic boundaries in Openfoam 1.5 | fs82 | OpenFOAM | 37 | November 29, 2024 11:15 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 12:25 |
Cyclic Boundary Condition | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Running, Solving & CFD | 36 | July 2, 2012 13:23 |
[mesh manipulation] Using createPatch in place of couplePatches | sripplinger | OpenFOAM Meshing & Mesh Conversion | 8 | November 13, 2009 08:14 |
reconstructParMesh not working with an axisymetric case | francesco | OpenFOAM Bugs | 4 | May 8, 2009 06:49 |
