How to use flow data of a as a boundary
Old   November 17, 2023, 00:23
Default How to use flow data of a as a boundary
Mike
mike1990 is on a distinguished road
Hello OF,
I want to solve a cyclic pipe for a long time and save flow data over a surface inside the pipe and then later use the written data as a boundary of a pipe that flows into a larger cubic domain. I know how to do pipe flow simulation, and I look for a way to use saved data as an inlet. The reason for this is that I want to have temporal and spatial fluctuation of flow to be included.
I am also familiar with mapped boundary conditions to use for fully developed flow... (does not work for my simulation)
Any help is appreciated.
M
mike1990 is offline   Reply With Quote
Old   November 17, 2023, 10:55
Josh Williams
joshwilliams is on a distinguished road
You can read and write openfoam fields and BCs with this python package (https://github.com/jvwilliams23/openfoamparser).
joshwilliams is offline   Reply With Quote
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
UDF for Automatic Solution Initialization for previous case data file gartz89 Fluent UDF and Scheme Programming 6 March 30, 2020 08:38
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
