Boundary conditions on atmosphere boundary
Old   November 15, 2023, 10:58
Default Boundary conditions on atmosphere boundary
Morteza
mortezahdr is on a distinguished road
I have a 3D domain initially filled with air. Based on the figure below, water is injected with a certain velocity from top left to the domain and moves through the domain. I am using interFoam. The figure shows iso-surface of alpha.water = 0.5. The boundary specified is atmosphere. The water is being accumulated after hitting that boundary.
My question is, what kind of boundary condition for p_rgh, U, and alpha.water should I use, so that the water leaves the domain instead of being accumulated after hitting the atmosphere boundary. Currently, these BCs are as follows:
U:
inlet
type flowRateInletVelocity;
volumetricFlowRate constant 7.22E-06;
atm
type pressureInletOutletVelocity;
value uniform (0 0 0);
_______________________________________
p_rgh:
inlet
type fixedFluxPressure;
value uniform 0;
atm
type totalPressure;
p0 uniform 0;
alpha.water:
inlet
type fixedValue;
value uniform 1;
atm
type inletOutlet;
inletValue uniform 0;
value uniform 0;
Thank you.
mortezahdr is offline   Reply With Quote
What are the best settings for a channel flow simulation? Ashkan Kashani CFX 3 October 13, 2022 22:36
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Radiation interface hinca CFX 15 January 26, 2014 18:11
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 08:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
