parafoam doesn't work
Old   November 15, 2023, 03:54
Default parafoam doesn't work
Tae Joon Kim
none990 is on a distinguished road
I'm using Centos stream 8
I want to see result with paraview but paraFoam command doesn't work
here's error message please help me
[hsu@localhost D_E_4]$ paraFoam
FATAL ERROR: The official reader module for OpenFOAM data does not exist on
your system. This means that the version of ParaView you are using was not
compiled with OpenFOAM, or distributed with a packaged version of OpenFOAM.
For information on packaged versions of OpenFOAM/ParaView and compilation of
OpenFOAM/ParaView, see https://openfoam.org/download
Alternatively, you might be able to view your OpenFOAM data with the reader
module provided with ParaView by running:
paraFoam -builtin
[hsu@localhost D_E_4]$ paraFoam -builtin
Created temporary 'D_E_4.foam'
/home/hsu/OpenFOAM/OpenFOAM-10/bin/paraFoam: line 66: paraview: command not found
none990 is offline   Reply With Quote
Old   November 15, 2023, 04:18
Tae Joon Kim
[QUOTE=none990;860052]I'm using Centos stream 8
paraFoam -builtin
I already tried to re-install paraview with Thirdparty-10 and its showing same message now
Old   November 15, 2023, 15:52
Troy Snyder
tas38 is on a distinguished road
Is paraview installed at all on your machine?
From command line...
paraview &
If so, from within your openfoam case directory...
touch case.foam
Then navigate to the directory in paraview and open 'case.foam'
tas38 is offline   Reply With Quote
parallel InterFoam solving does not work (single core does work) jordy OpenFOAM Running, Solving & CFD 0 February 2, 2023 08:11
paraFoam crashes in loading polyhedral mesh Ramkumar21194 OpenFOAM Post-Processing 0 July 5, 2022 12:10
"Number of faces in face and owners does not match" in paraFoam (topological changes) sheaker OpenFOAM Running, Solving & CFD 3 October 30, 2019 21:22
First order in fvSchemes does not seem to work gerritgroot OpenFOAM Running, Solving & CFD 0 September 30, 2015 21:06
[OpenFOAM] Weird Problem with ParaFoam via SSH cwang5 ParaView 2 July 19, 2010 10:00
