[blastFoam] Consider the mass of the explosive/detonation
Old   November 10, 2023, 10:11
Post [blastFoam] Consider the mass of the explosive/detonation
Jessie Burlasa
its.engrjessie is on a distinguished road
Hello everyone, I am now doing a research using blastFoam and I have this question that is hoping for an answer. I am trying to modify this blastfoam case using a tnt instead of C4, may I know how should I change the weight of the detonation? Say I am modelling a 2 kg TNT inside the the structure, what file should I modify and how shall I do it? Thank you so much and hoping for your response. God bless or the same case of using a 1 kg RDX. I am curious on what part of the solver do I need to specify the mass of the detonation.
its.engrjessie is offline   Reply With Quote
Old   September 27, 2024, 14:54
Default Follow up
Nick Kakavitsas
nkakavit is on a distinguished road
Hello, I'm running into the same issue. Did you ever find a resolution to this question? Thanks!
nkakavit is offline   Reply With Quote
blastfoam, mass, tnt
mass fraction of species Lilly FLUENT 5 March 13, 2022 18:52
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Coupled Heat and Mass Transfer Mecroob OpenFOAM Running, Solving & CFD 1 July 12, 2020 20:24
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 11:30
Mass sources - help! Emmanuel Resch Siemens 11 May 29, 2008 11:20
