type limitTemperature problem
Old   November 9, 2023, 08:53
Post type limitTemperature problem
Adam
AdamRM is on a distinguished road
Forum members,
I am using OpenFoam-2206 patch=221104, solver HiSA.
I would like to introduce a temperature limit into the calculations and I get this error:
[19] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[19] Unknown fvOption type limitTemperature
Valid fvOption types :
1(radiation)
[19]
[19]
[19] file: stream.limitTemperature1 at line 0.
[19]
[19]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[19]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[19]
FOAM parallel run exiting
fvOption file, the commented content are various attempts to implement the limit:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  9
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
    object      fvOptions;
limitTemperature1
        // Mandatory entries (unmodifiable)
        type            limitTemperature;
        // Mandatory entries (runtime modifiable)
        min             101;
        max             1000;
        // Optional entries (runtime modifiable)
        //phase           <phaseName>;
        // Mandatory/Optional (inherited) entries
    limitTemperature1
        selectionMode all;
    	active     true;
        min             101;
        max             1000;
temperatureLimit
    active true;
    limitTemperatureCoeffs
        selectionMode all;
        min 101;
        max 1000;
bound_T
    type            temperatureLimitsConstraint;
    selectionMode   all;
    active          true;
    temperatureLimitsConstraintCoeffs
        Tmin     101;
        Tmax     1000;
source1
    selectionMode   all;
    active          true;
            Tmin     101;
            Tmax     1000;
limitT
    active          yes;
    selectionMode   all;
    min             200;
    max             500;
    phase           gas; // optional
limitT
    selectionMode all;
    active     true;
    min        101;
    max        1000;
Can anyone help?
AdamRM is offline   Reply With Quote
Old   November 10, 2023, 08:52
Adam
Dear All,
Maybe someone has any idea?
Old   November 10, 2023, 13:15
Lorenzo
Lorenzo210 is on a distinguished road
Originally Posted by AdamRM View Post
Dear All,
Hi Adam,
It seems that the solver does not load correctly the fvOptions available.
Maybe is it not loading some library? It's hard to tell since it is a custom solver.
I took a really quick look at the "options" file inside the "Make" directory of the hisa solver.
It misses this library:
-lfvOptions \
I would first try to add the before mentioned line to the options file and see if it works.
If the issue persists, it could be a good idea to contact the developer of the solver.
Regards,
Lorenzo
Lorenzo210 is offline   Reply With Quote
Old   November 13, 2023, 09:51
Adam
Dear Lorenzo,
Thank you for your interest in the topic and for your answer.
Could you tell me how exactly I should add "-lfvOptions " at the "options" file inside the "Make" directory of the hisa solver?
Thanks,
Adam
Old   November 13, 2023, 10:13
Lorenzo
Assuming you're using the singleRegionModels:
I would try add the line in "hisa/applications/singleRegionSolvers/hisa/Make/options"
Under -lmeshtools \
Maybe you should also add the following to the file "#include "fvOptions.H" " in "hisa/applications/singleRegionSolvers/singleRegionSolver.H" under the line "#include "fvCFD.H" "
Best,
Lorenzo
Old   November 13, 2023, 11:32
Adam
Dear Lorenzo,
Thank you for the tip, unfortunately it did not fix the error.
Do you or anyone else have any other ideas?
I paste the entire error code below:
Selecting finite volume options type limitTemperature
[0]
[0]
[0] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[0] Unknown fvOption type limitTemperature
1(radiation)
[0]
[0]
[0] file: system/fvOptions.limitTemperature1 at line 27 to 33.
[0]
[0]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[0]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[0]
[0]
[22]
[23]
[23]
[23] [30]
[30]
[30] --> FOAM FATAL IO ERROR: (openfoam-2206[31]
[31]
[31] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[31] Unknown fvOption type limitTemperature
1(radiation)
[31]
[31]
[31] [13]
[13]
[13] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[13] Unknown fvOption type limitTemperature
1(radiation)
[13]
[13]
[13] file: stream.limitTemperature1 at line 0.
[13]
[13]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[13]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[13]
[13]
[16]
[16]
[16] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[16] Unknown fvOption type limitTemperature
1(radiation)
[16]
[16]
[16] file: stream.limitTemperature1 at line 0.
[16]
[16]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[16]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[16]
[16]
[19]
[19]
1(radiation)
[19]
[19]
[19]
[19]
[19]
[27]
[27]
[27] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[27] Unknown fvOption type limitTemperature
1(radiation)
[27]
[27]
[27] file: stream.limitTemperature1 at line 0.
[27]
[27]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[27]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[27]
[27]
[29]
[29]
[29] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[29] Unknown fvOption type limitTemperature
1(radiation)
[29]
[29]
[29] file: stream.limitTemperature1 at line 0.
[29]
[29]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[29]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[29]
[29]
[23] Unknown fvOption type limitTemperature
1(radiation)
[23]
[23]
[23] file: stream.limitTemperature1 at line 0.
[23]
[23]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[23]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[23]
[23]
 patch=221104)
[30] Unknown fvOption type limitTemperature
1(radiation)
[30]
[30]
[30] file: stream.limitTemperature1 at line 0.
[30]
[30]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[30]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[30]
[30]
[1]
[1]
[1] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[1] Unknown fvOption type limitTemperature
1(radiation)
[1]
[1]
[1] file: stream.limitTemperature1 at line 0.
[1]
[1]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[1]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[1]
[1]
[2]
[2]
[2] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[2] Unknown fvOption type limitTemperature
1(radiation)
[2]
[2]
[2] file: stream.limitTemperature1 at line 0.
[2]
[2]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[2]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[2]
[2]
[3]
[3]
[3] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[3] Unknown fvOption type limitTemperature
1(radiation)
[3]
[3]
[3] file: stream.limitTemperature1 at line 0.
[3]
[3]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[3]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[3]
[3]
[5]
[5]
[5] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[5] Unknown fvOption type limitTemperature
1(radiation)
[5]
[5]
[5] file: stream.limitTemperature1 at line 0.
[5]
[5]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[5]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[5]
[5]
[6]
[6]
[6] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[6] Unknown fvOption type limitTemperature
1(radiation)
[6]
[6]
[6] file: stream.limitTemperature1 at line 0.
[6]
[6]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[6]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[6]
[6]
[7]
[7]
[7] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[7] Unknown fvOption type limitTemperature
1(radiation)
[7]
[7]
[7] file: stream.limitTemperature1 at line 0.
[7]
[7]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[7]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[7]
[7]
[10]
[10]
[10] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[10] Unknown fvOption type limitTemperature
1(radiation)
[10]
[10]
[10] file: stream.limitTemperature1 at line 0.
[10]
[10]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[10]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[10]
[10]
[11]
[11]
[11] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[11] Unknown fvOption type limitTemperature
1(radiation)
[11]
[11]
[11] file: stream.limitTemperature1 at line 0.
[11]
[11]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[11]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[11]
[11]
[31]
[31]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[31]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[31]
[31]
[14]
[14]
[14] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[14] Unknown fvOption type limitTemperature
1(radiation)
[14]
[14]
[14] file: stream.limitTemperature1 at line 0.
[14]
[14]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[14]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[14]
[14]
[15]
[15]
[15] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[15] Unknown fvOption type limitTemperature
1(radiation)
[15]
[15]
[15] file: stream.limitTemperature1 at line 0.
[15]
[15]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[15]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[15]
[15]
[17]
[17]
[17] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[17] Unknown fvOption type limitTemperature
1(radiation)
[17]
[17]
[17] file: stream.limitTemperature1 at line 0.
[17]
[17]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[17]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[17]
[17]
[22]
[22] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[22] Unknown fvOption type limitTemperature
1(radiation)
[22]
[22]
[22] file: stream.limitTemperature1 at line 0.
[22]
[22]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[22]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[22]
[22]
[18]
[18]
[18] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[18] Unknown fvOption type limitTemperature
1(radiation)
[18]
[18]
[18] file: stream.limitTemperature1 at line [21]
[21]
[21] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[21] Unknown fvOption type limitTemperature
1(radiation)
[21]
[21]
[21] file: stream.limitTemperature1 at line 0.
[21]
[21]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[21]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[21]
[21]
0.
[18]
[18]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[18]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[18]
[18]
[26]
[26]
[26] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[26] Unknown fvOption type limitTemperature
1(radiation)
[26]
[26]
[26] file: stream.limitTemperature1 at line 0.
[26]
[26]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[26]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[26]
[26]
MPI_ABORT was invoked on rank 23 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[9]
[9]
[9] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[9] Unknown fvOption type limitTemperature
1(radiation)
[9]
[9]
[9] file: stream.limitTemperature1 at line 0.
[9]
[9]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[9]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[9]
[9]
[12]
[12]
[12] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[12] Unknown fvOption type limitTemperature
1(radiation)
[12]
[12]
[12] file: stream.limitTemperature1 at line 0.
[12]
[12]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[12]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[12]
[12]
[20]
[20]
[20] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[20] Unknown fvOption type limitTemperature
1(radiation)
[20]
[20]
[20] file: stream.limitTemperature1 at line 0.
[25]
[25]
[25] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[25] Unknown fvOption type limitTemperature
1(radiation)
[25]
[25]
[25] file: stream.limitTemperature1 at line 0.
[25]
[25]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[25]     in file cfdTools/general/fvOptions/fvOption.C at line 104[28]
[28]
[28] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[28] Unknown fvOption type limitTemperature
1(radiation)
[28]
[28]
[28] file: stream.limitTemperature1 at line 0.
[28]
[28]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[28]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[28]
[28]
[4]
[4]
[4] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[4] Unknown fvOption type limitTemperature
1(radiation)
[4]
[4]
[4] file: stream.limitTemperature1 at line 0.
[4]
[4]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[4]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[4]
[4]
[20]
[20]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[20]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[20]
[20]
[25]
[25]
[8]
[8]
[8] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[8] Unknown fvOption type limitTemperature
1(radiation)
[8]
[8]
[8] file: stream.limitTemperature1 at line 0.
[8]
[8]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[8]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[8]
[8]
[24]
[24]
[24] --> FOAM FATAL IO ERROR: (openfoam-2206 patch=221104)
[24] Unknown fvOption type limitTemperature
1(radiation)
[24]
[24]
[24] file: stream.limitTemperature1 at line 0.
[24]
[24]     From static Foam::autoPtr<Foam::fv::option> Foam::fv::option::New(const Foam::word&, const Foam::dictionary&, const Foam::fvMesh&)
[24]     in file cfdTools/general/fvOptions/fvOption.C at line 104.
[24]
[24]
[serwersymulacje:231141] 31 more processes have sent help message help-mpi-api.txt / mpi-abort
[serwersymulacje:231141] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Old   November 16, 2023, 06:55
shock77 is on a distinguished road
some years ago I implemented it in rhoCentralFoam:
Sudden Increase of residuals
I use OpenFOAM 5, but I hope it will work more or less the same way.
shock77 is offline   Reply With Quote
activeBaffleVelocity boundary condition ? om3ro OpenFOAM Programming & Development 10 November 17, 2020 00:26
Film cooling problem arun1994 OpenFOAM 0 October 26, 2020 10:08
Problem with continuity simpleFoam kkl omega airfoils ibelunatic OpenFOAM Running, Solving & CFD 0 March 20, 2018 12:48
rhoPimpleFoam hardship petrus OpenFOAM Running, Solving & CFD 0 October 7, 2016 03:41
singularity? mihaipruna OpenFOAM Running, Solving & CFD 5 April 24, 2012 18:18
