fvSchemes for DES
Old   November 7, 2023, 13:01
Exclamation fvSchemes for DES
Saeed Jamshidi
saeed jamshidi is on a distinguished road
Hello Foamers,
I'm going to use DES for my simulation. I have read that in DES the scheme is specified using:
divSchemes
    default         none;
    div(phi,U)      Gauss DEShybrid
        linear                        // scheme 1
        linearUpwind grad(U)          // scheme 2
        0.65                          // DES coefficient, typically = 0.65
        30                            // Reference velocity scale
        2                             // Reference length scale
        0                             // Minimum sigma limit (0-1)
        1                             // Maximum sigma limit (0-1)
        1e-3;                         // Limiter of B function, typically 1e-03
Besides, in order to use the scheme, libs ("libturbulenceModelSchemes.so") must be added to controlDict.
Althouth I'v done this procedure, I,v come across fatal error:
file: stream.divSchemes.div(phi,U) at line 0.
[2]
[2]     From static Foam::tmp<Foam::surfaceInterpolationScheme<Type> > Foam::surfaceInterpolationScheme<Type>::New(const Foam::fvMesh&, const surfaceScalarField&, Foam::Istream&) [with Type = Foam::Vector<double>; Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>]
[2]     in file lnInclude/surfaceInterpolationScheme.C at line 114.
[2]
FOAM parallel run exiting
[2]
[3]
[3]
[3] --> FOAM FATAL IO ERROR: (openfoam-2112 patch=220610)
[3] Unknown discretisation type DEShybrid
Valid discretisation types :
63
CoBlended
Gamma
GammaV
LUST
MUSCL
MUSCLV
Minmod
MinmodV
OSPRE
OSPREV
Phi
QUICK
QUICKV
SFCD
SFCDV
SuperBee
SuperBeeV
UMIST
UMISTV
biLinearFit
blended
cellCoBlended
clippedLinear
cubic
cubicUpwindFit
deferredCorrection
downwind
filteredLinear
filteredLinear2
filteredLinear2V
filteredLinear3
filteredLinear3V
fixedBlended
limitWith
limitedCubic
limitedCubicV
limitedLinear
limitedLinearV
limiterBlended
linear
linearFit
linearPureUpwindFit
linearUpwind
linearUpwindV
localBlended
localMax
localMin
midPoint
outletStabilised
pointLinear
quadraticFit
quadraticLinearFit
quadraticLinearUpwindFit
quadraticUpwindFit
reverseLinear
skewCorrected
upwind
vanAlbada
vanAlbadaV
vanLeer
vanLeerV
weighted
weightedFlux
How can I handle this problem?
thanks.
saeed jamshidi is offline   Reply With Quote
Old   November 7, 2023, 13:37
Domenico Lahaye
dlahaye is on a distinguished road
What do tutorials do?
dlahaye is offline   Reply With Quote
Old   November 7, 2023, 13:40
Saeed Jamshidi
Dear dlahaye, thank you for the prompt reply.
Which tutorial, do you know which tutorial is the best fit?
Old   November 7, 2023, 13:57
Domenico Lahaye
Any tutorial using DES on a sufficiently small mesh, I imagine.
Unix is your best friend.
tut
cd incompressible
for jfile in `find . -name turbulenceProperties` ; do echo $jfile; grep -i des $jfile; done
Old   November 7, 2023, 14:53
Saeed Jamshidi
I cloudn't find the problem
Here are my fvschemes & fvsolution:
|  \\    /   O peration     | Version:  v2112                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         backward;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
divSchemes
    default         none;
        linear                        // scheme 1
        1                            // Reference velocity scale
        0.04                             // Reference length scale
    div(phi,k)      Gauss limitedLinear 1;
    div(phi,omega)  Gauss limitedLinear 1;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method          meshWave;
    nRequired       yes;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver          GAMG;
        smoother        DICGaussSeidel;
        tolerance       1e-06;
        relTol          0.05;
    pFinal
        $p;
        relTol          0;
    "(U|k|omega)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-6;
        relTol          0.1;
    "(U|k|omega)Final"
        $U;
        relTol          0;
    cellDisplacement
        solver          GAMG;
        tolerance       1e-6;
        relTol          0;
        smoother        GaussSeidel;
SIMPLE
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
PIMPLE
    nOuterCorrectors 1;
    nCorrectors      3;
    nNonOrthogonalCorrectors 1;
    pRefCell        0;
    pRefValue       0;
relaxationFactors
    fields
        p               0.3;
    equations
        "(U|k|omega)"   0.7;
        "(U|k|omega)Final" 1.0;
cache
    grad(U);
I will appreciate any assistance.
Old   November 8, 2023, 02:54
Domenico Lahaye
I do suggest running a tutorial that uses DES first.
Use Unix tools to find such a tutorial.
Old   November 8, 2023, 06:16
Saeed Jamshidi
Dear dlahaye, thank you again for the reply.
I looked at all of my tutorials and there was not any DES turbulence model!!
Furtheremore, by reading below thread I'm going to accept that maybe my openfoam v2112 does not support DEShybrid !!
k-omega SST IDDES Setup
Old   November 8, 2023, 06:41
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hello Saeed,
As Domenico suggested, you can use Unix tools to search for things in the tutorials.
For instance, this should lead you to tutorials using DEShydrid:
grep -r "DEShybrid" $FOAM_TUTORIALS
Yann
Yann is offline   Reply With Quote
Old   November 8, 2023, 07:05
Saeed Jamshidi
Thank all of you.
I saw them, and for the periodic hill case SpalartAllmarasIDDES turbulent model is used with the fvschem of:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         backward;
gradSchemes
divSchemes
    default         none;
        linear                    // scheme 1
        hmax
        0.028                     // Reference length scale
        1; // 1.0e-03;                  // Limiter of B function, typically 1e-03
    div(phi,nuTilda) Gauss limitedLinear 1;
laplacianSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method          meshWave;
    nRequired       yes;
and I'm going to use kOmegaSSTIDDES. However, my fvscheme is:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         backward;
gradSchemes
divSchemes
    default         none;
        linear                        // scheme 1
laplacianSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method          meshWave;
    nRequired       yes;
major difference is in divSchemes part, where I should consider omega instead of nutilda (SpalartAllmaras model).
I am wondering about this really!!!!
Old   November 8, 2023, 08:20
Domenico Lahaye
It should suffice to extend
to
Old   November 9, 2023, 05:09
Saeed Jamshidi
Finally, I found the problem, and I want to share it for readers of this thread.
Please, refer to here:
Error in fvSchemes TGS OpenFOAM 0 May 10, 2023 12:20
fvschemes for laminar particles of fluidisedBed gryphaea1635 OpenFOAM Pre-Processing 1 April 26, 2020 17:10
First order in fvSchemes does not seem to work gerritgroot OpenFOAM Running, Solving & CFD 0 September 30, 2015 21:06
Unrealistic values in cells at edge (high pressure & velocity) - fvSchemes?! matzbanni OpenFOAM Running, Solving & CFD 8 August 24, 2015 17:46
fvschemes and fvsolutions in MRFSimpleFoam renyun0511 OpenFOAM Running, Solving & CFD 23 August 3, 2011 05:07
