Convection Boundary condition for Temperature
Old   November 6, 2023, 06:24
Default Convection Boundary condition for Temperature
Vishal Garg
Vishal Garg is on a distinguished road
Hello Everyone
I am simulating my model using the chtMultiRegionSimpleFoam. In my model fluid is going down through annulus and coming back from inner pipe so it is basically a counter flow heat exchanger.
As the heat transfer takes place from one fluid to another through solid region so
Please suggest me the Temperature boundary condition at the solid-fluid interface
Thanks
Vishal Garg is offline   Reply With Quote
Old   November 6, 2023, 07:16
Yann
Yann will become famous soon enoughYann will become famous soon enough
for CHT simulations the BC for fluid/solid interfaces is usually compressible::turbulentTemperatureRadCoupledMixed.
Name may vary depending on the OpenFOAM version you are using. Check chtMultiRegionSimpleFoam tutorials to see what boundary condition is used.
Regards,
Yann
Yann is offline   Reply With Quote
Old   November 7, 2023, 01:35
Vishal Garg
Thanks Sir for reply
but Sir i am using incompressible fluid (water) in my simulation study.
can i use this BC for incompressible fluid also?
Thanks
Old   November 7, 2023, 04:56
Yann
chtMultiRegionSimpleFoam is a compressible solver, this is why the boundary condition is related to compressible class.
You can use it for water.
Yann
Old   November 7, 2023, 08:44
Vishal Garg
Sir, is there any solver for solving heat transfer and fluid flow simultaneously for Incompressible fluids?
or should i mention incompressible in chtMultiRegionSimpleFoam ?
Thanks
Old   November 7, 2023, 09:18
Vishal Garg
Sir, I have read in one thread that set incompressible (rhoConstant )in Thermophysical properties, does not couple heat transfer and fluid flow.
is this true?
if this is true then what equation of state should i choose for coupling of heat and fluid flow.
should i use icopolynomial or something else?
Thanks
Applying convection as internal boundary condition? evanJ FLUENT 4 January 28, 2019 10:49
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
