hot to write mDotAlphal() field during compressibleInterFoam simulations
Old   November 5, 2023, 05:28
Default hot to write mDotAlphal() field during compressibleInterFoam simulations
nicola andreini
nicola_andreini is on a distinguished road
Good morning,
I am doing simulations using compressibleInterFoam, how can I write in simulation foalders the mDotAlphal() field associated with condensation and evaporation ?
I am using the SchnerrSauer model.
Foam::Pair<Foam::tmp<Foam::volScalarField>>
Foam::twoPhaseChangeModels::SchnerrSauer::mDotAlphal() const
const volScalarField& p =
mixture_.U().db().lookupObject<volScalarField>("p" );
const volScalarField pCoeff(this->pCoeff(p));
const volScalarField limitedAlpha1
min(max(mixture_.alpha1(), scalar(0)), scalar(1))
return Pair<tmp<volScalarField>>
Cc_*limitedAlpha1*pCoeff*max(p - pSat(), p0_),
Cv_*(1.0 + alphaNuc() - limitedAlpha1)*pCoeff*min(p - pSat(), p0_)
nicola_andreini is offline   Reply With Quote
Old   November 5, 2023, 06:25
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hello Nicola,
I don't know if it will work on your specific case, but have a look to the writeObjects function object. It allows to write variables which are registered to the database but not written to disk by default.
Regards,
Yann
Yann is offline   Reply With Quote
Old   November 5, 2023, 15:13
nicola andreini
Originally Posted by Yann View Post
Hello Nicola,
Regards,
Yann
Thank you very much, unfortunately I have tried but it is not possible to use writeObject for that type of objects.
Old   November 6, 2023, 03:38
Lorenzo
Lorenzo210 is on a distinguished road
Hi Nicola,
A simple way to do it could be creating a variable in createFileds.H and the assign the value of mixture->mDotAlphal(); somewhere after mixture->correct;
Beware that mDotAlphal() is a Pair, so you may use two different volScalarField objects to write each component on.
You can set the IOobject options to NO_READ and AUTO_WRITE, so the variable will be written in each folder and you won't need to set a value in the 0 folder.
Regards,
Lorenzo
Lorenzo210 is offline   Reply With Quote
cavitation model, compressibleinterfoam, evaporation condensation, kunz, schnerr-sauer
Write probability as a field scalar, such as P(Ux>0) in transient simulations chen112p OpenFOAM Post-Processing 0 February 11, 2023 16:22
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
How can write a field in openFOAM sven82 OpenFOAM Programming & Development 27 December 11, 2019 12:57
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
