November 3, 2023, 01:13 |
realizble KE fails for jet modeling
CFD_Lovers
Rep Power: 11 |
Hello Foamers!
I've been working on a jet flow simulation using both standard and realizable KE in OpenFOAM. The jet ejects into a stagnant water tank with higher density comparing with the water inside the tank. The problem arises when switching from standard to realizable k epsilon, iteration of k goes some time after start time, which varies depending on the initial values chosen for k and epsilon, to zero and eddy viscosity values shows weird results. In fact, the values of nut in jet surrounding are greater than their counterparts in jet! I was wondering if any body could provide me some advises regarding their experiences on these two models in openFOAM. Thank you, Sina |
November 6, 2023, 19:19 |
#2 | |
CFD_Lovers
Rep Power: 11 |
No comment? !! |
Turbulence Modeling - The Gist | Avr.Tomer | Main CFD Forum | 0 | September 28, 2019 00:13 |
side jet modeling for a missile: 1st order or 2nd order scheme | AmirBaqa1987 | ANSYS | 1 | March 19, 2014 05:39 |
May Focus Area: Turbulence Modeling | Jonas Larsson | CFD-Wiki | 0 | May 2, 2006 12:48 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 15:49 |
CFD Modeling of Two-phase Flow in Small Dia.Tubes | Eric Poindexter | Main CFD Forum | 2 | September 22, 2000 10:21 |
