Solver to use for simulation of heated airfoil/wing?
Old   November 2, 2023, 22:11
Default Solver to use for simulation of heated airfoil/wing?
TWB
quarkz is on a distinguished road
I need to perform simulation of heated airfoil/wing. So for e.g., the temperature at the airfoil top will be at 80deg while the bottom is 30deg.
I read in a paper which uses rhoSimpleFoam, which is a steady compressible solver.
In this case, there's heat transfer + density change to the heated air.
So must I use a compressible solver e.g. rhoPimpleFoam for this type of simulation?
Can I use an incompressible solver? I have been using pimpleFoam so I am more experienced with it.
Thanks!
quarkz is offline   Reply With Quote
Population Balance Modeling (PBM) - Ansys Fluent chittipo FLUENT 164 November 18, 2023 12:54
Will the results of steady state solver and transient solver be same? carye OpenFOAM Running, Solving & CFD 9 December 28, 2019 06:21
2D differentially heated cavity, which is appropriate solver? vetnav OpenFOAM 12 July 6, 2017 06:49
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
