Particle Flow in liquid medium => kinematic pressure?
Old   October 31, 2023, 03:08
Unhappy Particle Flow in liquid medium => kinematic pressure?
Enea Baumann
bumi-the-man is on a distinguished road
Hi guys,
I'm struggling a bit with the following problem:
I want so simulate a simple pipe flow with particles (straitght pipe with inlet and outlet). The bulk fluid is water-like, Newtonian liquid whereas the particles are alginate particles with a density close to the one of water and a average diameter of 900um. I manage to solve the case with the MPPICFoam solver, however, the pressure always acts super weird. There are strange pressure fluctuations and unphysical sudden changes in the kinematic pressure. Also, the pressure does not converge during solving. The velocity field looks plausible.
I tried to adapt the fvSchemes and fvSolution files, but nothing really resolves the problem. I took the fvSchemes and fvSolution from existing cases for incompressible, lagrangian particle-flow problems where all use air as their continuous medium - this might be the issue since in my case, the continuous phase is much denser and more viscous. I change from GAMG to PCG solver for pressure and increased the convergence criteria. But it didn't change anything
I also tried to solved only the flow field of the bulk phase without particle using MPPICFoam, and there, the pressure looked good. So as soon as particles are introduced, the pressure starts to act weird...
I also played around with the boundary conditions. Do you have an suggestion for a suitable setup of fvSchemes and fvSolutions?
fvSchemes
|  \\    /   O peration     | Version:  v2212                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         Euler;
d2dt2Schemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(alphaPhi.cont,U.cont)    Gauss linearUpwindV unlimited;
    div(((alpha.cont*nuEff.cont)*dev2(T(grad(U.cont))))) Gauss linear;
    div(phiGByA,kinematicCloud:alpha) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-10;
        relTol          0;
    pFinal
        $p;
        relTol          0;
    pcorrFinal
        $p;
        relTol          0;
    U.cont
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-05;
        relTol          0.1;
    U.contFinal
        tolerance       1e-05;
        relTol          0;
        tolerance       1e-06;
        relTol          0;
PIMPLE
    nOuterCorrectors 1;
    nCorrectors     2;
    momentumPredictor yes;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
    checkMeshCourantNo  no;
    correctPhi          no;
relaxationFactors
    fields
        ".*"            1;
    equations
        ".*"            1;
0/p
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
	inlet1
   		 type            zeroGradient;
  	outlet
    	    type            fixedValue;
    	    value           uniform 0;
    walls
        type            zeroGradient;
0/U.cont
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U.cont;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
	inlet1
 	type            fixedValue;
	value           uniform (0.3 0 0);
 outlet
        type            zeroGradient;
	value           uniform (0 0 0);
    walls
        type            noSlip;
Last edited by bumi-the-man; October 31, 2023 at 05:49. Reason: Added residual plot
bumi-the-man is offline   Reply With Quote
lagrange particle, mppic foam, mppicfoam, partial pressure, particles motion
unable to run dynamic mesh(6dof) and wave UDF shedo Fluent UDF and Scheme Programming 0 July 1, 2022 18:22
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate MSchneid Fluent UDF and Scheme Programming 3 February 23, 2019 07:00
BC for Actuator Disk - Flow Vel from High Pressure to Low Pressure vinguva OpenFOAM Running, Solving & CFD 2 March 8, 2016 00:46
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
