Parallel run error while running the simulation using MPPICFoam
Old   October 30, 2023, 05:14
Default Parallel run error while running the simulation using MPPICFoam
kazzy is on a distinguished road
I am getting below error when i run ./Allrun command to solve.
fileName::stripInvalid() called for invalid fileName /home/ttdesign/OpenFOAM/ttdesign-v2206/run/EAIPS-NEW/p1_noBladesScaled(copy)
For debug level (= 2) > 1 this is considered fatal
Primary job terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
mpiexec detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[34815,1],1]
Exit code: 1
Would be happy to provide the Allrun file as follows for your further investigation. You help would be much appreciated. Thanks
Allrun script is as follows:
#!/bin/sh
cd "${0%/*}" || exit # Run from this directory
. ${WM_PROJECT_DIR:?}/bin/tools/RunFunctions # Tutorial run functions
# CLEANING THE CASE
rm log1_clean
rm log2_mesh
rm log3_checkMesh
rm log4_decomposePar
rm log5_parallelRun
rm log6_reconstructPar
rm -r log5_parallelRun.analyzed
rm -r VTK
foamCleanTutorials | tee log1_clean
# CONVERTING FLUENT MESH TO FOAM
ideasUnvToFoam Mesh_1_meters.unv | tee log2.mesh
# COPING THE ORIGINAL 0 FOLDER TO MAKE IT EXECUTIBLE 0 FOLDER
cp -r 0.orig 0
cp constant/boundary.orig constant/polyMesh/boundary
# CHECKIMG THE MESH
checkMesh | tee log3_checkMesh
#foamToVTK
#foamToVTK -faceSet nonOrthoFaces
#foamToVTK -pointSet nonManifoldPoints
#foamToVTK -pointSet unusedPoints
#foamToVTK -faceSet upperTriangularFace
# SPLITTING THE CASE FOR 16 PROCESSORS
decomposePar | tee log4_decomposePar
# RUNNING THE SIMULATION
mpiexec -np 16 MPPICFoam -parallel | tee log5_parallelRun
#pyFoamPlotWatcher.py log5_parallelRun
# RECONSTRUCTING THE CASE
reconstructPar | tee log6_reconstructPar
kazzy is offline   Reply With Quote
Old   October 30, 2023, 06:19
Yann
Yann will become famous soon enoughYann will become famous soon enough
Not sure about it, but I would try removing the brackets in the case name.
Yann
Yann is offline   Reply With Quote
Old   October 30, 2023, 07:32
That doesnt help as I am getting same error for any file name. Please suggest further. Thanks.
mppicfoam, parallel running
parallel vs serial run interFoam - dambreak gentodin OpenFOAM Running, Solving & CFD 0 February 21, 2022 02:31
Error running simpleFoam in parallel Yuby OpenFOAM Running, Solving & CFD 14 October 7, 2021 05:38
SimpleFoam cannot open include file Marija OpenFOAM Running, Solving & CFD 1 October 28, 2020 11:35
OpenFOAM can't be run in parallel in cluster sibo OpenFOAM Running, Solving & CFD 4 February 21, 2017 17:29
How to run parallel simulation on PC with two-CPU? Jimmy FLUENT 1 July 14, 2008 01:46
