solve the equation looks like heat conduction equation |
October 27, 2023, 07:58 |
zw
I want to use OenFOAM to solve a partial differential equation,which looks like heat conduction equation. But its "thermal diffusion coefficient" is less than 0. It is fvm::ddt(T) - fvm::laplacian(DT, T) == 0 But its Dt < 0. I tried to use laplacianFoam, but the calculation failed. "Floating point exception" appears. Can someone tell me how to adjust my laplacianFoam case, or which solver I should choose? |
October 27, 2023, 11:18 |
Rep Power: 14 |
Is the equation not unstable with a negative diffusion coefficient, i.e. working as intended?
Think of a simple case of 1D heat conduction in a bar with a negative heat diffusivity - any gradient would automatically try steepen instead of diffuse. So I can imagine that your solution would run away quickly, and ultimately crash. |
laplacianfoam, openfoam |
About Heat Flux Equation in StarCCM+ manual | jshu004 | STAR-CCM+ | 1 | March 26, 2020 09:40 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Heat transfer (conduction) between two pipes | shields | FLUENT | 14 | February 3, 2016 07:45 |
Use advection step and Dispersion step to solve advection diffusion equation | cooljd | Main CFD Forum | 0 | October 15, 2012 15:44 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
