total pressure keeps increasing with wrong pressure drop
Old   October 25, 2023, 14:58
Question total pressure keeps increasing with wrong pressure drop
JuPB is on a distinguished road
I am trying to run an internal flow simulation with hot air. In order to check if the model is ok, I compare the theorical pressure drop of a 90 degrees elbow to the value obtained in the simulation. I was expecting a value closer to 20 Pa but I am getting something around 400 Pa. I think that it might be a problem with my turbulence setup because when running with wallfunctions in either w or nut the solution diverges. Can someone help me with the setup, please? I did compare it with tutorials and other threads but I can't see what I am doing wrong.
After a while, pressure drop stabilizes but total pressure keeps increasing and in some cases it diverges. Why is this happening? Also, I was not expecting negative values for total pressure. How is it possible?
JuPB is offline   Reply With Quote
Pressure fields in FOAM, p field, total pressure, etc. Tobi OpenFOAM Post-Processing 9 March 25, 2022 02:33
udf error srihari FLUENT 1 October 31, 2016 15:18
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 14:04
Multiphase Fluidized bed- WRONG pressure drop prediction mail.leonardo FLUENT 0 January 23, 2015 18:18
Boundary Conditions : Total Pressure or Velocity Gearb0x OpenFOAM Running, Solving & CFD 2 February 28, 2011 22:18
