MoveDynamicMesh for a cylinder. Good mesh in serial. Bad mesh in parallel
Old   October 25, 2023, 09:40
Default MoveDynamicMesh for a cylinder. Good mesh in serial. Bad mesh in parallel
M. Montero
be_inspired is on a distinguished road
Hi All,
OpenFoam version: 2212
I am simulating a cylinder with a prescribed deformation based on the z-coordinate. After playing a little bit with the laplacian solver, it works ok in serial. The mesh is ok for every time step. I am using moveDynamicMesh for testing purposes before launching the pimpleDyMFoam.
The problem is that, it fails in parallel and the quality issues are located more or less where the partitions are located.
Here you can find my dynamicMeshDict. Defining the interpolation method did a great improvement due to the special characteristics of the mesh (y+=1, high aspect ratio cells near the surface).
I have tried scotch and simple for the decomposition, 2 or 8 processors. There are always problems but in different regions of the mesh.
I have tried commsType blocking; but there is no effect.
Any clue about how to solve it?
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      dynamicMeshDict;
dynamicFvMesh dynamicMotionSolverFvMesh;
motionSolverLibs ("libfvMotionSolvers.so");
solver      displacementLaplacian;
displacementLaplacianCoeffs {
    diffusivity quadratic inverseDistance (cylinder);
    frozenPointsZone frozenZone;
    interpolation patchCorrected
            (cylinder)
Best Regards
M
be_inspired is offline   Reply With Quote
Is my Mesh good or Bad jobingthampi FLUENT 2 October 14, 2023 08:07
[snappyHexMesh] Is it a good mesh for a square cylinder ? belier1988 OpenFOAM Meshing & Mesh Conversion 2 September 10, 2020 12:59
The problem when i use parallel computation for mesh deforming. Hiroaki Sumikawa OpenFOAM Running, Solving & CFD 0 November 20, 2018 03:58
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Good MEsh and a bad one Himanshu Sharma FLUENT 3 June 6, 2006 04:24
